Posted 31 August 2016 - 08:51 PM
But battery has at least 12v when car is off and when car is on, the alternator is charging at 13.4v
Why is my battery light on ??
Posted 31 August 2016 - 09:12 PM
Have you tested the battery under load? Some times putting a volt meter on it is not enough to determine if it's duff(faulty cells can hide themselves well)
All terminals on the battery are good and clean with good contact?
Could be something even more simple like a bad earth.
Have you installed anything new that could draw too much of a current?
Posted 31 August 2016 - 09:14 PM
It is not a battery light, it is an alternator light. It tells you ONLY that the alternator is not charging. And 13.4V is too low, you need to see 14.4V.
Most likely your alternator is faulty, or the alternator side of the lamp has shorted to earth, which may prevent the alternator working properly. The current through the lamp is necessary for initial magnetisation of the armature coil. So pull out the alternator plug (NEVER run teh engine with it out) and check that the lamp is now out, with ignition on of course. If it stays on, you have a wiring fault.
Before condemning the alternator, thoroughly check and clean the engine and battery earths, battery positive terminal, and the stack of wires on the solenoid battery terminal. That means taking them apart, cleaning the faces with a mild abrasive, and tightening them up carefully. Check the fan belt and pulleys. Get all the cheap fixes done first, before trying the expensive one, a new alternator.
But before you do any of that, maybe you could tell us whether you have done anything recently to the car, and when did the problem arise, just in case there is something else that we can suggest.
Posted 31 August 2016 - 09:20 PM
Posted 31 August 2016 - 09:27 PM
Italianjob, what you said was good, and definitely worth checking too.
Posted 01 September 2016 - 01:29 AM
before this happened, i had radiator, water pump, thermalstat, and heater hoses replaced ....after all this, the lamp wwent on
Posted 01 September 2016 - 08:37 AM
Is the fan belt slipping?
Posted 01 September 2016 - 11:22 AM
Also tagged with one or more of these keywords: electrical, engine
Mini Technical Sections →
Problems, Questions and Technical →
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
