1275 Breather System - Connecting To Carb
Best Answer driftz , 07 September 2016 - 01:29 PM
Iv done a very similar thing for the same reasons. No reason not to if your not using it for coolant
Go to the full post
35 replies to this topic
#31 MrJenkinsEsq
MrJenkinsEsq
  • 38 posts
Posted 29 October 2016 - 10:08 AM
http://www.theminifo...inlet-manifold/
A good thread on the water heated debate. My first engine had it plumbed in, and the first time I took it to be tuned on the rolling road at MiniSport, the operator told me to bypass it, so I bowed to his greater knowledge and suppose I've never really questioned it since.
#32 neal
neal
  • 318 posts
Posted 29 October 2016 - 05:15 PM
Too much heat in the inlet tract robs power and too cold causes icing
You are quite correct but the water heated manifolds don't introduce too much heat. Vizard notes that for most engines the loss of power will be a near imperceptible 1hp. It's a worthy sacrifice for the improvements it provides in other areas.
It's a little tangential to the point but it's notable on engines with longer intake tracts (my LandRover is a good example) that heated manifolds provide much better economy figures because the improvement in atomisation counters the reduced charge density. The same problem is evident for fuel injection - wall wetting (X-Tau).
What I'm really getting at is that it's not always clear cut that hot intake == bad - like any analogue system, it's a balancing act.
Your absolutely right, that's why I wrote 'Too much heat in the inlet tract robs power and too cold causes icing' I didn't bother to comment on the grey area in between too hot and too cold due to the lengthy post and I do like to leave a bit of meat on the bone for others to have a chew on, (keeps the thread/topic on the boil) I think we're all versed on Vizard's book and if some are not then It maybe a good time to plug the book.
Plenty of bedtime reading there, don't you agree??
Edited by neal, 29 October 2016 - 05:28 PM.
#33 Spider
  • 15,143 posts
Posted 29 October 2016 - 08:05 PM
For out and out Horsepower, yes, but for a street car, I'd leave it connected.
It will give improved fuel usage and smoother idle / low speed running when connected.
#34 Dusky
Dusky
  • 5,322 posts
Posted 29 October 2016 - 10:29 PM
You're All tempting me to connect Mine now :P
Do you still go to the heater matrix?
#35 Spider
  • 15,143 posts
Posted 29 October 2016 - 10:33 PM
It can make for a tidier hose layout if you are connecting in the heater (and who wouldn't want that?).
#36 neal
neal
  • 318 posts
Posted 30 October 2016 - 04:40 AM
Good point, but who wants to be at idle? I want to be in the happy gear (3rd) going through those little lanes and to be fair fuel mileage is going to be the last thing on my mind.
Drive it man....... and forget about the petrol penny pinchers!!
(Although, if you are worried about fuel mileage, go on and buy a modern 'plastic fantastic' hybrid)
Edited by neal, 30 October 2016 - 04:50 AM.
