Special Tools Required For Engine Dismantle/build
33 replies to this topic
#1 Shaggy33
Shaggy33
  • 311 posts
Posted 07 September 2016 - 10:10 PM
See my other threads to find out why I'm asking this! I have all the usual tools- sockets, spanners, torque wrench, impact wrench etc but wondered if any speciality tools are required to strip/rebuild a series engines and gearboxes? For instance piston ring compressors or any bearings that need to be press fitted?
#2 nicklouse
  • 18,657 posts
Posted 07 September 2016 - 10:13 PM
Haynes manual.
Flywheel puller.
Bearing puller
Plastiguage.
Feeler gauges
Dial gauges
Ring compressors.
Blow torch.
All mentioned in the Haynes manual.
Ball joint splitters pot jot poppers.
Cv boot tie tools.
#3 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 07 September 2016 - 10:24 PM
Valve spring compressor
#4 Dusky
Dusky
  • 5,322 posts
Posted 07 September 2016 - 10:46 PM
Imperial equivalent of a 34 and 38mm socket . Those dont come in the std sets. :)
#5 Icey
Icey
  • 1,551 posts
Posted 07 September 2016 - 11:28 PM
Plastiguage.
I thought general advice was to use a micrometer as it can also give an indication of roundness?
#6 nicklouse
  • 18,657 posts
Posted 07 September 2016 - 11:32 PM
Add micrometer and vernier gauges as well.
And a good steel edge/rule.
#7 rally1380
rally1380
  • 1,893 posts
Posted 08 September 2016 - 08:15 AM
selotape
#8 Shaggy33
Shaggy33
  • 311 posts
Posted 08 September 2016 - 08:45 AM
Cheers guys
I just need plastiguage, dial gauge, ring compressor and valve spring compressor then:-) can live with that.
Oh and I have loads of sellotape, will the clear invisible stuff do :lol:  :lol:  :lol:
#9 rally1380
rally1380
  • 1,893 posts
Posted 08 September 2016 - 09:21 AM
Cheers guys
I'm serious about needing sellotape......you will need it on the rebuild.
#10 Shaggy33
Shaggy33
  • 311 posts
Posted 08 September 2016 - 09:26 AM
what for, to get all the iron filings off my clothes...?!
#11 tiger99
tiger99
  • 8,584 posts
Posted 08 September 2016 - 11:00 AM
I have never needed sellotape for a rebuild. I must have used alternative methods. Where would you need it?
#12 MacGyver
MacGyver
  • 1,027 posts
Posted 08 September 2016 - 11:05 AM
A big hammer... for hitting the sellotape when things go wrong. 😀
#13 MrJenkinsEsq
MrJenkinsEsq
  • 38 posts
Posted 08 September 2016 - 11:20 AM
I found a decent stand with a magnetic base was really useful when using the dial gauge for measuring end float and cam timing.
It's a bit of a specific one, but I believe there's a specialist spring compressor that you can get (or make) for changing the bendix on an inertia starter motor.  It's one of those things that you only find out when you need to do it :)
#14 rally1380
rally1380
  • 1,893 posts
Posted 08 September 2016 - 02:05 PM
To cover the splines of the primary gear to stop them damaging the seal.  Sellotape with some oil on stops any damage that sharp edges of gear teeth could cause.  I think there is a proper tool for the job, but I've used sellotape and it does the job....think I read about it in Vizard's book....or maybe the Haynes manual.
#15 rally1380
rally1380
  • 1,893 posts
Posted 08 September 2016 - 02:06 PM
Well hopefully you won't have iron filings on your clothes during the rebuild..........see above comment for the real reason.
