Sound Insulation
24 replies to this topic
#1 Gsi_Joe
Gsi_Joe
  • 66 posts
  • Local Club: CumbriaMiniCruisers
Posted 08 September 2006 - 05:27 PM
Well, as my girlfriend's driving little Austin, she seems to get headaches etc from the engine noise :w00t:
Now there is no dash whatsoever at the moment, but thats in hand...
...I was just thinking there's a lot of space behind where the dashboard will go, and I could perhaps 'fill' that with some sort of sound-proofing material.
Is this wise? :proud:
I was just thinking along the lines of foam, polystyrene, bubble-wrap etc!
Any ideas??
Joe
P.S. I suggested ear muffs but that idea went down like a lead ballon :w00t:
#2 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 08 September 2006 - 05:37 PM
Im not sure but i would like to know two, i was going to fill the space behind the dash with as much cloth as i could pack behind the dash but i didnt do it yet as i thought that it might burn the dials and the head unit. So i would like to know to :proud:
#3 blacktulip
blacktulip
  • 6,224 posts
Posted 08 September 2006 - 06:02 PM
the sound deadening mat that goes under the bonnet along the top behind the carb is very good at cutting out the noise, fitting a new one is worth it as its better than the standard foam one. i would try that first.
#4 1984mini25
1984mini25
  • 8,785 posts
Posted 08 September 2006 - 08:01 PM
Go down to B&Q and buy a roll of the grey carpet underlay for about £25, which is slightly ticker than the tailored felt kits, which the one I bought didn’t fit the way I would of likes. So I’ve done the whole of my mini in the stuff including floors, boot, roof and two layers behind the dash, helps cut down the noise and keep the cabin warm during the colder months.
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 September 2006 - 08:17 PM
Bitumen roof flashing tape ( on the inside two layers on the bulkhead ) you could have a v8 in the engine bay and not hear it
k that's an exageration, but will cut out a LOT of engine noise ( do the whole car and it'll sound like a merc )
#6 minivanman
minivanman
  • 3,454 posts
Posted 08 September 2006 - 08:39 PM
plus roof banding is cheap as chips :w00t: not like dynamat or "proper" sound proofing! and it does the job just as well.
#7 Gsi_Joe
Gsi_Joe
  • 66 posts
Posted 08 September 2006 - 09:02 PM
Ah right, thanks people!
Is THIS the kind of thing you mean?
Does it just stick on like duck tape then? Is it likely to trap moisture anywhere once i've stuck two layers on?
Oh, and where do I buy it, B&Q etc??
Thanks for your help!
Joe :w00t:
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 September 2006 - 09:10 PM
I wish we had that tape over here! I've never seen anything comparable at our home centers and DIY places. It sure sounds cheaper than Dynamat.
#9 dizzle
dizzle
  • 143 posts
Posted 08 September 2006 - 09:31 PM
Dude...
I got some stuff off ebay called "FATMAT"
it is sticky one side and has a layer of ally foil on t'other, the foil helps turn the vibration (noise) into low level heat....
I have used 1 roll (£38 aprox) and would recon another 2 to do the whole inside + boot and maybe under bonnet (not the roof)
my mate had the same problem as u and used the fatmat, it works very well blocking out the noise and the suck of carb
But this stuff is real heavy
good luck with your choice!!
diz :w00t:
Edited by dizzle, 08 September 2006 - 09:35 PM.
#10 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 08 September 2006 - 09:53 PM
The mighty Guesswork is right about the roof flashing, it's bloody brilliant at sound deadning.
with regards to trapping moisture.... it'll only 'trap' moisture, if you don't apply it to a dry surface!
#11 Gsi_Joe
Gsi_Joe
  • 66 posts
Posted 08 September 2006 - 10:10 PM
Thanks for the replies everyone! :w00t:
Well, it would seem the flashing tape idea is winning at the moment, it seems a lot cheaper too!
Cool, thats what I thought but just wanted to make sure...
Cheers,
Joe :(
#12 biggav
biggav
  • 5,830 posts
  • Local Club: South Central
Posted 08 September 2006 - 10:38 PM
great... i knocked off 20 rolls of flashband from a company who went bust oweing me thousands!!! guess what i'm doing tommorow!!!
#13 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 08 September 2006 - 10:55 PM
U fancy selling me some some with the boot lid.
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 09 September 2006 - 07:17 AM
4 rolls of 225mm x10m will do the entire car, doors, floor, boot rear quarters bulkhead, and add another if yu want to do the roof... Will cost about 14-15 quid a roll from Homebase, B&Q, Wicks etc etc etc
If you want to get a realy good fit ( ie no air pockets ) use a heat gun to gently soften it into place.. I've done two cars with it now and swear by it if you want a quiet car..
#15 Tomf
Tomf
    Baby Tom
  • 6,440 posts
Posted 09 September 2006 - 09:32 AM
So where can you buy roof flashing tape, would some where like B&Q sell them.
