Will cost about 14-15 quid a roll from Homebase, B&Q, Wicks etc etc etc
Sound Insulation
#16
Posted 09 September 2006 - 09:41 AM
#17
Posted 09 September 2006 - 09:42 AM
4 rolls of 225mm x10m will do the entire car, doors, floor, boot rear quarters bulkhead, and add another if yu want to do the roof... Will cost about 14-15 quid a roll from Homebase, B&Q, Wicks etc etc etc
If you want to get a realy good fit ( ie no air pockets ) use a heat gun to gently soften it into place.. I've done two cars with it now and swear by it if you want a quiet car..
Read the bit in Bold!!!!!
LOL Bounce beat me to it!!
Edited by miniboo, 09 September 2006 - 09:42 AM.
#18
Posted 09 September 2006 - 09:57 AM
#19
Posted 09 September 2006 - 01:23 PM
#20
Posted 09 September 2006 - 01:57 PM
#21
Posted 10 September 2006 - 09:01 PM
1 more will finish roof and rear floor i reckon, then next weekend i'll do the boot and rear quarters.
The car is soooo much more driveable now, may actually consider a stereo, before hand it was too loud to even think about.
#22
Posted 10 September 2006 - 09:47 PM
I only ask as mine are very good at holding water!!
need to sort all the rust holes and then i will use this stuff i think
#23
Posted 10 September 2006 - 10:00 PM
So are you using this tape to replace the spongey sound insulation under the carpet.
yeah... when i rebuilt rusty, i didn't bother with any foam... or carpets.... this stuff is highly tacky black stuff with a metalic dull side (non stick) to resemble lead when used in building applications. i had painted the floor pan with Hammerite and undersealed the underside, then rolled the flashband out and cut it into useable strips (about 450 mm long) and applied it... i then cut some up smaller to fill in the gaps... the result is water proof, soundproof but sticky as hell.... i'll reapply the underseal every 6 months as i don't fancy ever trying to get the flash band off for welding!!!!!
#24
Posted 10 September 2006 - 10:02 PM
got any pics?
#25
Posted 10 September 2006 - 10:09 PM
