I thought i would share my engine spec, reason for doing so is you can get good power
for fast road without spending a fortune and may give you some ideas
my engine has just been on dyno at Slark giving 80hp at 5800 and 80 torque at 4700
the engine is a 1275 mg metro engine
a very nice new stage 3 head, compression around 10.1
block was honed and new rings
crank grind to 10 new main bearings and big ends new thrusts
bottom end was all balanced
original mg metro cam and followers (i like the mg cam but havent tried others similar so maybe more power there ) )
dizzy is a lucas 64d modded curve by AC Dodd, and 40,000 volt coil bp7es plugs
new oil pump and water pump with 70 lb oil pressure hot
timing chain ( but only dots lined up on timing gear so maybe some more power here )
original rocker gear but new shaft, tappets set to 14 and 16 ex
standard clutch but balanced with new diaphragm and turbo plate
valvoline VR1 20 50 changed at every 2000 miles
gearbox had new bearings and diff rebuilt with moly pin and 3.44 dif
hif 44 modded to vizard spec with med substack and ramair filter and mg metro manifold
maniflow stage 2 lcb and twin box (but larger mid and rear for quietness maybe loosing some power here )
am realy happy the way car performs its ideal for b roads where i use it 2 or 3 days a week
the engine was actually built 5 years ago now done 21000 miles and should last a bit
but the head and modded carb only just fitted so had to go back to dyno
the head and modded dizzy certainly made a noticeable difference
have probably missed some things done but gives the main info
