Hi guys
I am thinking of fitting a metro leccy dizzy to our 998, do I need to find one from a 998 or would one from a 1275 work?
Thanks in advance
David
Daft question I think
nomininolife
, Sep 09 2006 09:14 PM
2 replies to this topic
Posted 09 September 2006 - 09:14 PM
Posted 09 September 2006 - 09:43 PM
There are none of that type (64DE4) set up for the 998 and while the 1275 one will allow the engine to run it doesn't work all that well with the 998 cam. It needs the advance curve in it tweaking a little. This can be done by specialists such as MLM or you can use the Aldon Ignitor or Luminition Magnetronic ignition kits in your standard dizzy, the later being based on the 64DE4 ignition pack anyway and so essentially giving you the same dizzy.
Posted 09 September 2006 - 09:46 PM
Thanks Dan
Would it work any better with an MG metro cam?
Edited by nomininolife, 09 September 2006 - 09:47 PM.
