Fan Not Coming On
Posted 28 September 2016 - 10:37 AM
Posted 28 September 2016 - 10:51 AM
Edit: If you take the sender out, plug it in, turn the contact on ( don't start engine or you'll have a mess!!!), and heat up the sender you should see if it is that...
Edited by MacGyver, 28 September 2016 - 11:01 AM.
Posted 28 September 2016 - 11:04 AM
when you say it overheated what actually happened?
The fact that when you unplug the sensor the fan kicks in proves that the ecu/loom/sensor are communicating as they should
Posted 28 September 2016 - 11:10 AM
Hens testing the sender by heating it artificially with a lighter or something, holding it with a pair of pliers of corse... 😀
Posted 28 September 2016 - 11:11 AM
Posted 28 September 2016 - 11:16 AM
what does the gauge say?
are you losing water?
Posted 28 September 2016 - 11:29 AM
Posted 28 September 2016 - 11:59 AM
Posted 29 September 2016 - 02:13 PM
how sure are you of the temperature being at 105? how have you measured it?
Posted 01 October 2016 - 12:20 PM
Posted 19 October 2016 - 11:43 AM
maybe the issue is the coolant cap leaking. I've had the same problem some time ago - it appeared that the cap could not hold the pressure in the coolant tank. Due to low pressure in the tank, the coolant boiled. Try messing with the cap itself, maybe loosen it a bit or make it tighter.
Posted 22 October 2016 - 07:51 AM
No just what gage says iv put a new sensor in and new thermostat still not coming on just wondering if there's a brack in the wires frome the sensor to the lome ???
the fact that when you unplug the sensor the fan comes on proves there are no brakes in the loom
