If your lights failed due to a blown fuse then there is an issue that would cause the fuse to blow and subsequently it would need to be resolved, as opposed to a full on fire by shorted wires.
What happens if you have a failed alternator which leads to a dead battery?
Most would switch the hazards on on a dark Road if they'd lost there lights....
And to clarify, the supply to the relays in my kit isnt fused, only the supply out of the relays to the lamps. And then each lamp and beam pattern has a separate fuse (4 in total). Furthermore the sidelights are separately powered, hence the user would never be in total darkness.
Overall the kit is safer than the original wiring due to the introduction of a dedicated power supply controlled by amply rated relays and fuses for left/right and dipped/main.
Many thanks
Edited by WiredbyWilson, 03 October 2016 - 07:27 PM.
