Oil Issue, Not A Leak Tho
Posted 02 October 2016 - 08:39 PM
Posted 02 October 2016 - 08:43 PM
Posted 02 October 2016 - 08:44 PM
What is your real question?
Posted 02 October 2016 - 08:51 PM
Some.
How much oil should be getting flung around the rocker box? That's all, I thought there would be a fair bit but I'm.not getting much.
Posted 02 October 2016 - 08:56 PM
When everything's in good order, there is some, but not 'a lot'.
The Oil feed to the Rockers is restricted by the Cam Shaft. There's two off-sets slots on it to 'pulse meter' the Oil going up there.
Posted 02 October 2016 - 09:02 PM
Posted 02 October 2016 - 09:12 PM
You are aware that you need to have a rocker pedestal with an oil hole in over the oil feed hole in the head.
And you need to have the rocker shaft in the correct way with grub screw fitted and locked.
Posted 02 October 2016 - 09:56 PM
My father was a mechanic and I have seen him run push rod engines with the rocker cover off after having set all the clearances to double check nothing was wrong with the engine and he or the engine bay didn't get covered in oil. So the answer is not a lot of oil is sprayed around at low engine rpm.
Posted 02 October 2016 - 10:47 PM
Ok.
I bought them used and just fitted them as I got them, I'll find out how they are meant to go.and check mine
