I am trying remove the engine from my mini but as I have never done this before on a car (only bikes) I am a bit stumped.
How do I remove the gear thingy? seems like there is a little pin in the middle do I just bang it out?
Also how on earth do you remove the axles? they have some rubber coverf over them that I can't get off Is there a special way if doing it or am I being too nice to them?
Any help would be great!
Removing Engine
Doodles McPooh
, Sep 10 2006 12:25 PM
6 replies to this topic
Posted 10 September 2006 - 12:25 PM
Posted 10 September 2006 - 12:31 PM
That pin is a roll pin and the haynes politely says you should 'drift' it out with a drift pin (i think that's what it's called, might be a punch). so yeah just whack it out. Try putting it into different gears to get at both pins and try to watch where they go when they fly out!
Are you using a Haynes manual?
Edited by Pooky, 10 September 2006 - 12:32 PM.
Posted 10 September 2006 - 12:36 PM
Got a hayne manual but it didn't seem that clear maybe I was reading the wrong bit.
Just didn't want to whack it out without asking as I have a habit of breaking stuff
Posted 10 September 2006 - 12:45 PM
put the lever towards but not in reverse and it should be easier to get it out.
tyhink you need a 4mm punch/drift. i used a knackered drill bit the right size.
Posted 10 September 2006 - 12:48 PM
thanks
has anyone got any ideas on the axles?
Posted 10 September 2006 - 01:52 PM
do you mean the drive shafts on the front??
I rocked mine out, completely disconnected the engine from the car but stil had it in the engine bay,... undid the CV joints (what you call the rubby thingies) by undoiung the cable tie or bit of wire holding them on, and then rocked the engine sideways, one pops out, other way, the the pops out.
Edited by Retro_10s, 10 September 2006 - 01:53 PM.
Posted 10 September 2006 - 03:43 PM
if u have undun all the ball joints round the hub you can just give them a sharp yank they should just pop out, wel they did on my m8s scrapper! but if u are leaving the hubs where they are go with retro 10s idear
