fast idle
19 replies to this topic
#1 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 10 September 2006 - 01:38 PM
hey guys odd one for u, running a HS4 carb on my 998, but my problem is iv just fitted my maniflow single box system and the idle is majorly high! i mean almost screaming high! iv tried sotrting the mixture out and its still runnig fast, also it sounds really chopper sounding you know really raggady?
got a pipercross come filter on there now, that seemed to help a bit, but its still running fast, the only other thing i can think of is a leak on the carb to inlet gasket (thanks pikey7 for pointing that out) any other idears?!?!?!?!?!?!?!?!? im stumped?!?! :w00t:
Edited by minipip, 10 September 2006 - 01:46 PM.
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 10 September 2006 - 01:47 PM
dude, you need a different needle in your carb now surely, you'll be running lean with a new box and cone filter so you'll need a differnt needle to let more fuel thorugh. try putting the old filter back on and see what happens. best thing to do would be to put it all back as it was. then a you add stuff,. try the engine, as soon as it starts playing up again, you know what's causing it.
sounds a bit like fuel starvation as the engine is trying hard to get fuel, and so the revs shoot up, try pulling the choke out and see if it calms it down a bit.
also, spraying WD40 over tall the joints when the engine is running will show up air leaks with bubbles. fi you're not sure if it's bubbling get someone to wang a rag over the exhaust end as it forces more air out if there is a leak.
Edited by Retro_10s, 10 September 2006 - 01:48 PM.
#3 minipip
minipip
  • 1,591 posts
Posted 10 September 2006 - 02:47 PM
well he runds worse with the original box on looks like he just needs the new needle now then, what can u guys recomend? im basicly running a 998, with that system, pipercross filter, sports coil, still running points. oh its an LCB manifold. also where can i get it form? minispares?
#4 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 10 September 2006 - 03:15 PM
dunno dude, but you're basically running a stage 1 kit now i guess.
have look on suppliers websites and see what needles come with the stage 1 kits.
alternatively try giving Somerford minis a call, they've always bee very very helpful to me over the phone, and reaaaaally know their stuff.
P.S.> which remind me.... have you done the pimp dash and headlining yet buddy?
#5 minipip
minipip
  • 1,591 posts
Posted 10 September 2006 - 03:20 PM
dash is done :w00t: headlineing is after all the mecanics is done for the mot, can anyone recomend any partuillar needle? thanks guys
#6 Pooky
Pooky
  • 5,691 posts
Posted 10 September 2006 - 03:40 PM
I think (can't emphasise the 'think' enough) I've got an AAU needle with my maniflow setup which came with my kit, but even that couldn't have been perfect as the guy who set mine up on the rollers whipped it out and filed it to gain best performance...
Edited by Pooky, 10 September 2006 - 03:40 PM.
#7 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 10 September 2006 - 03:44 PM
No you're quite right! AAU is the standard needle that 'generally' come with stage one kits,
but of course, no needle is PERFECT for a car without filing it slightly, but it shuold do the trick well enough.
Pip, perhaps purchase a needle for you carb, fit it and then get your car down a mini friendly rolling road. that'll put the smile bakc ony our face!
AAU should sort it out well enough for you to have a driveable car.
#8 minipip
minipip
  • 1,591 posts
Posted 10 September 2006 - 03:46 PM
cheers pooky! will order that friday, minispares
£8 ?!?!?!?! :'(
ne1 know newhere cheeper?
#9 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 10 September 2006 - 03:48 PM
£8 is about right, might be able to get them for £7 lol.
#10 Big_Adam
Big_Adam
  • 7,435 posts
Posted 10 September 2006 - 04:17 PM
*starts making notes*
got to rember this for my lil' el gordo when i get me a stage one.
#11 stef
stef
  • 799 posts
Posted 10 September 2006 - 10:37 PM
i seem to remember something on minispares about AAU and AAM. AAU was for the standard airbox with k&n, AAM was for the same but with the airbox drilled. i use an AAA on mine. and thats not right.
i'd say bust out winsu and compare the needles. look for the one thats thinner at idle, will make it richer.
then again im just babbling, probably best to ignore me =D
#12 supermotolee
supermotolee
  • 1,120 posts
Posted 10 September 2006 - 11:00 PM
yeah i had an aaa on my 998 with similar setup...
#13 minipip
minipip
  • 1,591 posts
Posted 11 September 2006 - 04:04 PM
how did that run?
so what am i going for?
AAM?
AAU?
AAA?
because i think im just gonna order AAU? as that seemes to come in the stage1 kit?!?!?!
#14 Jammy
Jammy
  • 25,397 posts
Posted 11 September 2006 - 09:29 PM
Get it rolling roaded.
#15 minipip
minipip
  • 1,591 posts
Posted 11 September 2006 - 10:45 PM
thats next on the list need to get the right needle in so he runs, i just need him running close to ok, hes my daly runner!
