Diff Output Shaft Wobble
Posted 23 October 2016 - 12:41 PM
Only problem is the r/h output shaft has quite a bit of wobble.
Should I be concerned?
I assume it's these at fault?
http://www.minispare...ck to catalogue
Posted 23 October 2016 - 01:30 PM
Ac
Posted 23 October 2016 - 02:15 PM
Doesn't the bronze bush stop the pot joint from wobbling? Pot joints are still on the driveshafts (still in the car) rather than diff output shafts at the minute.
Posted 23 October 2016 - 02:17 PM
Posted 23 October 2016 - 02:20 PM
Posted 23 October 2016 - 03:39 PM
Posted 23 October 2016 - 03:59 PM
Posted 23 October 2016 - 04:16 PM
I wouldn't say so, that's what the bushes in the covers are for. You're quite a way from the bearing there, which exaggerates the play in the bearing. The bearings are really working as a pair to support the diff, the planet gears balance the torque on either side of the output shaft so it can't create the side loads you are in the vid.
Posted 23 October 2016 - 04:42 PM
It does, again there isn't much for it do because the pot joint and driveshaft is pretty well centred. Bushes are stronger than bearings because they have more contact area, a bearing would need more running clearance (as you've discovered) to wouldn't centre as well - not good for the oil seals.
The diff bushes are similar to the crank mains bearings in how they work.
Posted 23 October 2016 - 05:47 PM
Posted 23 October 2016 - 06:00 PM
Is that amount of movement to be of concern if it's only a product of the bearing itself?
Posted 23 October 2016 - 06:08 PM
Ac
Posted 23 October 2016 - 06:20 PM
http://www.minispare...l.aspx?2~14~127
And the large bearing as per my original post is ok?
Posted 23 October 2016 - 08:11 PM
As well as the bushes, it'll also be the thrusts in the diff itself. They are fibre material these days, but many moons ago were bronze.
Until I started using Quaifes, I would either find an old Bronze set or cut new ones from a sheet.
This is the current thrust here
