In My Opinion - Some People Try It On
34 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 07 November 2016 - 12:31 PM
£8000 he is joking - look closely
http://www.ebay.co.u...tcAAOSw0UdXqFdp
#2 sledgehammer
sledgehammer
  • 3,098 posts
Posted 07 November 2016 - 12:52 PM
so a standard advantage - with bit's added
in Lamborghini White
love this - MOT HAS JUST BEEN DONE AND EXPIRES JULY 2017 ???
not worth asking price IMHO
edit just had a look on the PC - that is rough
Edited by sledgehammer, 07 November 2016 - 01:09 PM.
#3 Mrpeanut
Mrpeanut
  • 1,019 posts
  • Local Club: Wessex MOC
Love the comment that the gearbox has been changed for the quick shift !
Still, doesn't look a bad little mini but never worth 8 grand.
#4 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 07 November 2016 - 12:56 PM
Looks rough! Lots of rust and obvious filler repairs.
Bit of a dog but maybe 2500 with the wind behind it.
8k? Someone's a greedy lil swine lol
#5 sledgehammer
sledgehammer
  • 3,098 posts
Posted 07 November 2016 - 01:12 PM
also selling Tongue Scrapers Job Lot Wholesale Stainless Steel 1200 Pieces
don't a tooth brush do that ?
yep def greedy with that mini - wonder if someone will buy it because of the colour
Edited by sledgehammer, 07 November 2016 - 01:13 PM.
#6 1984mini25
1984mini25
  • 8,784 posts
Posted 07 November 2016 - 01:19 PM
Mot history makes interesting reading, lots of failures (twice in one year) and corrosion,
https://www.check-mot.service.gov.uk/
Check the MOT history of a vehicle
Registration number: D644ACX
  • Vehicle make ROVER
  • Vehicle model MINI
  • Date first used 1 July 1987
  • Fuel type Petrol
  • Colour White
MOT history of this vehicle
  • Test date 22 July 2016
  • Expiry date 21 July 2017
  • Test Result Pass
  • Odometer reading 33,761 miles
  • MOT test number 8891 7839 7402
  • Advisory notice item(s)
    Fuel Pipe/s corroded ()
  • Test date 15 July 2016
  • Test Result Fail
  • Odometer reading 33,755 miles
  • MOT test number 5435 1723 5285
  • Reason(s) for failure
    nearside Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
    offside Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
    nearside front lower Front suspension ball joint dust cover excessively deteriorated so that it no longer prevents the ingress of dirt (2.4.G.2)
    nearside front Brake hose excessively damaged (3.6.B.4d)
    nearside outer Subframe mounting prescribed area is excessively corroded sill (2.4.A.3)
    front Brake pipe excessively corroded to rear (3.6.B.2c)
  • Test date 10 September 2014
  • Expiry date 11 September 2015
  • Test Result Pass
  • Odometer reading 33,296 miles
  • MOT test number 3095 1325 4499
    Front suspension has slight play in a upper suspension ball joint (2.5.B.1a)
    Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
  • Test date 9 September 2014
  • Test Result Fail
  • MOT test number 7783 1215 4220
    Exhaust emissions carbon monoxide content excessive (7.3.B.1a)
    Brakes imbalanced across an axle (3.7.B.5b)
  • Test date 12 September 2013
  • Expiry date 11 September 2014
  • Test Result Pass
  • Odometer reading 33,188 miles
  • MOT test number 4652 3515 3266
    Nearside Front suspension has slight play in a lower suspension ball joint (2.5.B.1a)
    Offside Brake cable has wires broken but is not significantly weakened (3.5.1b)
  • Test date 5 September 2013
  • Test Result Fail
  • MOT test number 1072 8824 3232
    Offside Front Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Steering rack gaiter split (2.2.D.2d)
    Offside rear brake recording little or no effort (3.7.B.5a)
  • Test date 8 April 2013
  • Test Result Fail
  • Odometer reading 33,183 miles
  • MOT test number 2577 3859 3036
    Nearside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Offside Seat belt anchorage prescribed area is excessively corroded (5.2.6)
    Nearside Steering rack gaiter split (2.2.D.2d)
    Nearside Rear Sub-frame corroded and seriously weakened (2.4.G.1)
    Offside Rear Sub-frame corroded and seriously weakened (2.4.G.1)
    Nearside Track rod end ball joint has excessive play (2.2.B.1f)
  • Test date 5 April 2012
  • Expiry date 4 April 2013
  • Test Result Pass
  • Odometer reading 32,514 miles
  • MOT test number 4297 5679 2043
    Parking brake lever has little reserve travel (3.1.6b)
    Rear Vehicle structure has slight corrosion (6.1.B.2)
    Nearside Rear Vehicle structure has slight corrosion (6.1.B.2)
    Offside Rear Vehicle structure has slight corrosion (6.1.B.2)
    Offside Front suspension has slight play in a upper suspension ball joint (2.5.B.1a)
    Nearside Front wheel bearing has slight play (2.5.A.3c)
  • Test date 30 March 2012
  • Test Result Fail
  • MOT test number 4856 6049 2062
    Offside Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Offside Front Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
  • Test date 15 March 2011
  • Expiry date 14 March 2012
  • Test Result Pass
  • Odometer reading 31,358 miles
  • MOT test number 9481 8497 1029
    Vehicle structure has slight corrosion (6.1.A.1)
    Nearside Front Upper Suspension arm has slight play in a ball joint (2.4.G.2)
    Offside Front Upper Suspension arm has slight play in a ball joint (2.4.G.2)
    both rear handbrake cables slightly corroded
    Oil leak
  • Test date 7 March 2011
  • Test Result Fail
  • MOT test number 3096 3666 1037
    Direction indicators flashing more than 120 times a minute (1.4.A.2g)
    Rear Rear fog lamp not working (1.3.2b)
    Nearside Front Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
    Offside Front Headlamp excessively deteriorated so that the light output is severely reduced (1.7.5a)
    Oil leak
  • Test date 13 March 2010
  • Expiry date 12 March 2011
  • Test Result Pass
  • Odometer reading 30,290 miles
  • MOT test number 4734 9277 0067
  • Test date 6 March 2009
  • Expiry date 5 March 2010
  • Test Result Pass
  • Odometer reading 29,606 miles
  • MOT test number 1835 0506 9001
  • Test Result Fail
  • MOT test number 6044 7586 9090
    Front Windscreen washer provides insufficient washer liquid (8.2.3)
  • Test date 27 February 2009
  • Test Result Fail
  • Odometer reading 29,568 miles
  • MOT test number 5149 1865 9015
    Nearside Front Headlamp excessively damaged so that the light output is severely reduced (1.7.5a)
    Offside Rear Vehicle structure has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.B.2)
    Nearside Front Front suspension has slight play in a upper suspension ball joint (2.5.B.1a)
    Offside Front Front suspension has slight play in a upper suspension ball joint (2.5.B.1a)
    Nearside Vehicle structure has slight corrosion (6.1.B.2)
    Front Exhaust has a minor leak of exhaust gases (7.1.2)
  • Test date 9 October 2007
  • Expiry date 8 October 2008
  • Test Result Pass
  • Odometer reading 26,889 miles
  • MOT test number 1718 2238 7270
  • Test date 5 October 2007
  • Test Result Fail
  • MOT test number 9726 6897 7241
    Nearside rear brake recording little or no effort (3.7.B.5a)
    Offside Front Body has a sharp edge caused by corrosion (6.1.C.1)
    Nearside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
    Offside Rear Subframe mounting prescribed area is excessively corroded (2.4.A.3)
  • Test date 16 June 2006
  • Expiry date 24 June 2007
  • Test Result Pass
  • Odometer reading 26,503 miles
  • MOT test number 1205 2776 6169
  • Test date 13 June 2006
  • Test Result Fail
  • MOT test number 7447 6456 6128
    Nearside Front Front wheel bearing has excessive play (2.5.A.3c)
    Offside Rear Shock absorber has a serious fluid leak (2.7.3)
    Nearside Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
#7 scrumpix
scrumpix
  • 453 posts
  • Local Club: Yeovil Mini Mania
Posted 07 November 2016 - 01:38 PM
If you had 8K to spend there is so much better for the money
#8 racingbob
racingbob
  • 3,061 posts
Posted 07 November 2016 - 01:44 PM
did you see the bottom of the door and around the headlights
what about the engine bay i cracked up when i saw that
#9 slidehammer
slidehammer
  • 1,196 posts
  • Local Club: LSMOC
Posted 07 November 2016 - 01:48 PM
Look a bit of a tart up job to me, lets hope no one gets caught by it.
#10 Scousemouse
Scousemouse
  • 358 posts
Posted 07 November 2016 - 02:46 PM
All that don't mean a thing,MOT failures/rust and more rust......
we'll GLOSS over all the important things,because it's "WHITE"?? O_O ? sorry not white but "LAMBO WHITE"??? :ohno:  :ohno:
sort of ITALIAN EMULSION to be precise :D  :D
Nah I'll pass on this one me thinks
#11 Cooperman
  • 23,289 posts
Posted 07 November 2016 - 03:56 PM
It's 'fulla filla' - everywhere.
Probably worth around £2000 to £2500. The bodywork will cost, maybe, £3000 to get right or possibly more.
#12 JBW
JBW
  • 157 posts
  • Local Club: Mini Fixers
Posted 07 November 2016 - 04:27 PM
Quote from listing
"The purchaser of this car shouldn’t need to do anything for a good few years to this car now and with the right care and attention can be a part of your life for many years to come."
Makes my car look brilliant (which it certainly isn't), Even my inexperienced eye can see how rough the body & engine bay are, lets hope nobody gets caught out & thinks its a perfect car.
#13 wile e coyote
wile e coyote
  • 1,230 posts
Posted 07 November 2016 - 05:02 PM
Hmm - not a bad car - but should have had obvious crusty issues fixed before cheapo respray - more money spent on blingy bits than mechanicals & body.....never worth 8K!..... well not for a few years anyway!.... I think seller is asking what it cost rather than what it's worth....
#14 neal
neal
  • 318 posts
Posted 07 November 2016 - 06:11 PM
If they do sell it for that money the buyer is snow blind..........I am !
If they get anywhere near £4000 then I think we'll be quids in with our cars.
I bet the owner is practicing their sales pitch before applying to go on 'The apprentice'
#15 JCP
JCP
  • 74 posts
Posted 07 November 2016 - 07:29 PM
No, just no. £8k??!! He's dreaming isn't he?
