Epoxy Primer
28 replies to this topic
#1 pete l
pete l
  • 1,374 posts
Posted 09 November 2016 - 02:02 PM
Hi all,
Which epoxy primer should i go for ?
I don't want to die from using it either :-)
Pete
Edited by pete l, 09 November 2016 - 02:30 PM.
#2 pete l
pete l
  • 1,374 posts
Posted 09 November 2016 - 02:30 PM
Is epoxy mastic the same as epoxy primer ?
#3 Compdoc
Compdoc
  • 612 posts
Posted 09 November 2016 - 03:21 PM
I used Electrox primer then Epoxy Mastic, both from Bilt Hamber. http://www.bilthamber.com/ AFAIK little chance of killing yourself.
#4 pete l
pete l
  • 1,374 posts
Posted 09 November 2016 - 03:28 PM
I keep reading stories, not horror ones, about how important it is not to come into contact with the vapour of these paints, to have a ventilated and filtered painting booth and to have an air fed mask and all skin covered up because the poison can get into the body through the skin.
It's quite scary.
My brother was a panel beater, / sprayer all his life and passed away a couple of years ago from a massive heart attack at the age of 55.
Pete.
#5 mini-geek
mini-geek
  • 1,169 posts
Posted 09 November 2016 - 03:36 PM
I wouldn't worry too much about it a good cartridge mask and some ventilation will be adequate for a single exposure..
The main risks are for repetitive use..
#6 Hedgey
Hedgey
  • 179 posts
Posted 09 November 2016 - 06:18 PM
The above isn't good advise! People react differently to exposure to 2k paints and isocyantes. It's not worth the risk without the proper breathing equipment. Though I believe some (maybe all) epoxy primers do not contain isocyanates and can be sprayed with a good quality mask with the correct filters installed. It's always worth checking the products data sheet or contacting a reputable supplier and asking for their recommendation
#7 DeanP
DeanP
  • 499 posts
Posted 09 November 2016 - 06:39 PM
Rust.co.uk say their mastic primers and paints don't contain isocyanates.
It isn't cheap, but perhaps that's why. Have a look yourself.
http://www.rust.co.u...g-paint/c28117/
http://www.rust.co.u...-primer/c32736/
#8 Daz1968
Daz1968
  • 2,058 posts
Posted 09 November 2016 - 08:53 PM
Are you painting underside or top of shell, I have opted for epoxy mastic on underside and are using high build epoxy on external panels. Reason being it builds very well and easy to sand.
Epoxy paints are generally fine with a filter mask. I use a gerson mask. But as with everything download and read the MSDS for the exact paint you are planning to use. This will give all information you need
#9 pete l
pete l
  • 1,374 posts
Posted 10 November 2016 - 08:02 AM
I will be doing the whole car in epoxy, to seal it.
So epoxy mastic is epoxy primer ?
#10 pete l
pete l
  • 1,374 posts
Posted 10 November 2016 - 08:16 AM
looking on rust.co.uk site, i understand that epoxy mastic should be used for the underside and epoxy primer for the rest of the car. So they are not the same.
Here in France i'm having a job finding the correct paint.
#11 MacGyver
MacGyver
  • 1,027 posts
Posted 10 November 2016 - 09:13 AM
This is what I have.
Good for under the car too.
I got it in Switzerland, but it has lots of translations on it. 😀
#12 MacGyver
MacGyver
  • 1,027 posts
Posted 10 November 2016 - 09:15 AM
It is high build by the way...
#13 pete l
pete l
  • 1,374 posts
Posted 10 November 2016 - 10:22 AM
It says 2K on the tin, how long does it last one the two parts are mixed together ?
#14 pete l
pete l
  • 1,374 posts
Posted 10 November 2016 - 10:25 AM
I see that on the tin in english it says EPOXY FILLER
and in french it says EPOXY APPRET, translated means "primer"
This is why I am having a job finding it in France, I don't want filler, I want primer, but if they can't translate things correctly then I'm not sure what to buy.
#15 pete l
pete l
  • 1,374 posts
Posted 10 November 2016 - 10:27 AM
omg, I've found some,
http://www.peinturev...phatants-epoxys
Does anyone know this make ??
