Posted 11 November 2016 - 08:44 AM
They would not need to supply grease because these bushes do not rotate. They are only providing some small amount of compliance to the rear end to reduce noise and the stresses caused by bumps, as well as take up tolerances between body's he'll and subframe.
By the way, it is SILICONE grease. The E is very important, however the majority of so-called professional journalists (even in the Times and Torygraph, and frequently in the Daily Wail) get it wrong, so it is hardly surprising that the error spreads among the general public too. But the innards of your computer or iFad are based on SILICON chips without the E, although some of them may be encapsulated in SILICONE resin, with the E. The E denotes an organic compound with silicon replacing some or all of the normal carbon atoms. No E means that the raw element, usually with minute quantities of dopants to form the transistors etc, is being referred to.
Your wife/girlfriend (if any) does not need a SILICON transplant. The material is very hard and brittle!
If only the useless journalists would get things like that right, and disseminate accurate knowledge....
