Evening all - quick q for the knowledgeable - am refitting all hydraulics to my '80 car and like an idiot had all the pipes remade to the exact patterns I'd removed off my late unlamented spi - needless to say I'm retrofitting and aim to use the full system and servo from the later car (not to mention front sub / gear linkage and now carb equipped reworked engine.... fitting up this afternoon -new pedal box went straight in without protest (simple with the steering column out) and..... there's no way on earth the 2 pipes out of the top of the PWDA are going to fit ... the old pipes were dug out of the bin to check - spot on! so no go....I can redesign to make it fit - just...
So...dumb q - did they move the valve on injection cars? - maybe it moved up a bit and to the o/s more - thats the only theory I have that makes sense at the mo - there's a notch in the servo mounting bracket that suggests it....
