How Much Should The Camshaft Float?
20 replies to this topic
#16 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 24 November 2016 - 03:02 PM
How much movement in the chain have you got? Single or duplex?
by the way End float is best measured with a DTI ..
#17 jamesy
jamesy
  • 210 posts
Posted 24 November 2016 - 06:13 PM
Chain in pretty good, I would say that it's tight enough just with the two bolts in loose without any extra pressure. Simplex chain. There will be roughly 3-4mm movement on the side away from the tensioner, that's if you REALLY put effort into it.
Edited by jamesy, 24 November 2016 - 06:21 PM.
#18 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 24 November 2016 - 07:12 PM
I take it that is without the tensioner?
Edited by gazza82, 24 November 2016 - 07:13 PM.
#19 jamesy
jamesy
  • 210 posts
Posted 24 November 2016 - 07:23 PM
Yep, how much should it move? Haynes just say refit tensioner and tighten bolts.
#20 gazza82
gazza82
  • 3,014 posts
  • Local Club: TMF+
Posted 24 November 2016 - 08:20 PM
Well chains do stretch especially simplex and they aren't expensive when you think about it. The tensioner will take up the slack but if too much it will alter your timing.
Why not just fit a new one and take the worry out!
Edited by gazza82, 25 November 2016 - 11:27 AM.
#21 tiger99
tiger99
  • 8,584 posts
Posted 26 November 2016 - 02:26 PM
The last time I looked at one, the tensioner, comprising a neoprene pad, was non adjustable and is only a damper pad to prevent chain lash. It really should not be tight, and I would expect some running clearance.
But I can't say that there is only one type of tensioner, apart from the early rubber rings in grooves on the crankshaft pulley, which don't actually work.
