Which side of the carb is your float chamber on? There are 'LH' and 'RH' versions of the HS4.
when looking from the front its on the left side (aka the clutch side)
Posted 15 June 2017 - 10:04 PM
Posted 19 June 2017 - 09:31 PM
If the HS4 float chamber is on the clutch side then you may get fuel starvation when doing tight left hand turns.
Posted 20 June 2017 - 06:38 PM
