Fuel Pump Issues
24 replies to this topic
#1 muller295
muller295
  • 53 posts
Posted 28 November 2016 - 04:07 PM
Hi,
So I was working on my Mini and trying to get it to run, but the fuel pump didn't pump.
I then tested the pump by directly putting 12v on it and it worked.
So would should I check first and what could be the problem?
Thanks in advance!
#2 edkirk30
edkirk30
  • 42 posts
Posted 28 November 2016 - 04:13 PM
Checked the fuel cut off switch near the bulk head? Press from the top to reset. Looks like this:
http://minispares.co.../wqt100030.aspx
#3 muller295
muller295
  • 53 posts
Posted 28 November 2016 - 04:57 PM
No, I'll try tonight or tomorrow.
Do you just have to push or do you have to hold it or something?
#4 edkirk30
edkirk30
  • 42 posts
Posted 28 November 2016 - 05:06 PM
Yes just push down I believe. Your fuel pump should prime for a few seconds when the ignition is turned on, no need to try a start when testing.
#5 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 28 November 2016 - 05:55 PM
When I happened to experience the same, the fuse was burnt. I could not even see it with bare eyes.
#6 muller295
muller295
  • 53 posts
Posted 29 November 2016 - 04:02 PM
Ok, I tried the inertia switch today, didn't work unfortunately.
Then I went looking for the fuse, but when I tried to look up which one it was, I saw that I have a fusebox that isn't original (see spoiler).
Spoiler
So is there a fuse or is my car without a fuse?
My Mini is a 1992 SPI.
Thanks in advance
#7 muller295
muller295
  • 53 posts
Posted 29 November 2016 - 04:03 PM
-double post
Edited by muller295, 29 November 2016 - 04:03 PM.
#8 edkirk30
edkirk30
  • 42 posts
Posted 29 November 2016 - 04:10 PM
Does it still have the injector and ECU or has someone converted it to a carb? Maybe a post of the engine bay might help.
#9 genpop
genpop
  • 531 posts
Posted 29 November 2016 - 04:15 PM
Hello,
your SPI should have some line fuses behind or near by  the inertia switch.Have a look for a schematic, there are some links here in the forum.
According to my schematic line fuse Nr 4 colour NS
Good luck
Leopold
#10 edkirk30
edkirk30
  • 42 posts
Posted 29 November 2016 - 04:20 PM
You can probably scratch this comment, the early SPIs have a different fuse box to the later ones apparently
#11 FlyingScot
FlyingScot
  • 2,664 posts
Posted 29 November 2016 - 09:47 PM
Does it have an immobiliser ? Check for fuel pump relay action in the MFU (see Relay pack pinned thread)
FS
#12 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 30 November 2016 - 05:08 PM
Check the inline fuse with a white wire.
Take off your fuse box, clean it carefully also on the back and the connections and plugs. These fuse boxes tend to corrode on the backside.
Then measure at the fusebox connections re-installed  the voltage-in and voltage-out when ignition is on..
In one case I had voltage in normal and voltage out 5. That was not enough.
I Therefore changed the fuses of my SPI 93 and fixed a large modern blade fuse box with all fuses necessary. Since then peace with electrics.
Edited by Alpenflitzer, 30 November 2016 - 05:10 PM.
#13 muller295
muller295
  • 53 posts
Posted 01 December 2016 - 03:50 PM
Are the inline fuses the fuses in the picture in the spoiler in my previous post?
And is the one at the top (with the white wire) the fuel pump fuse?
In the spoiler below I put some pictures of my engine bay.
Spoiler
Edited by muller295, 01 December 2016 - 03:52 PM.
#14 genpop
genpop
  • 531 posts
Posted 01 December 2016 - 06:05 PM
those are the inline fuses and there are about 5 to 7in a spi
#15 muller295
muller295
  • 53 posts
Posted 02 December 2016 - 02:22 PM
Has anyone a list of all the fuses and which color belongs to it?
I checked the white inline fuse, looked good.
