Engine Choking On Hard Acceleration
6 replies to this topic
#1 Other-car-is-a-1275GT
  • 37 posts
Posted 07 December 2016 - 11:14 PM
1986 City E 998cc
1.5in SU
Engine chokes on any hard acceleration without the clutch engaged. It will eventually get to the higher revs but really doesn't like it as soon as you put the pedal to the floor.
It will crawl with the clutch engaged but as soon as the pedal is depressed too much it will choke and usually die if i persist.
I have replaced the Vac on the Dizzy as the previous one didn't hold pressure when sucking on it. Stole it off a new Dizzy, looked like a 45D. (Guessing a different type of vac wouldn't have fit my dizzy if it was the wrong type)
I have set the timing. 8 Degrees BTDC.
Mixture has been set using a colourtune. I also had a look on a emissions tester to double check.
Any suggestions to what i should do next?
I'm thinking a strip down of the carb see if i find any issues with that? Or a blown head gasket? (It's had a few of those..)
Cheers,
Adam
#2 sledgehammer
sledgehammer
  • 3,060 posts
Posted 07 December 2016 - 11:22 PM
Have you checked the dash pot oil , ?
if it is too thin , the carb piston will rise too quick , giving a weak mixture
is the spring in the dash pot - had a mini a while back had spring missing - would idle - but not rev
is the problem improved with the choke out ?
any air leaks ?
piped correctly?
check for compression if you suspect head gasket
less likely -
crankshaft end float can cause stall when using clutch - look at crank pulley while someone depresses the clutch pedal
Edited by sledgehammer, 07 December 2016 - 11:30 PM.
#3 cal844
cal844
  • 9,489 posts
  • Local Club: TFMOC
Posted 07 December 2016 - 11:36 PM
My thought would be the dizzy vac advance being the wrong curve(if changed as a complete unit)??
#4 sledgehammer
sledgehammer
  • 3,060 posts
Posted 08 December 2016 - 10:57 AM
while looking at the dizzi as above -
check the rotor arm moves & returns back to original position
have had a few in the past with seized outer shaft
suck on vacuum pipe , check base plate moves & returns - link may not be connected correctly
best of luck
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 08 December 2016 - 11:28 AM
Was it ever running well, or have you just done some work to it?
Edited by Stiggytoo, 08 December 2016 - 01:53 PM.
#6 Carlos W
Carlos W
  • 10,110 posts
Posted 08 December 2016 - 12:42 PM
What colour are the plugs?
#7 Other-car-is-a-1275GT
  • 37 posts
Posted 22 January 2017 - 09:04 PM
Thanks to all that replied, still don't really know what the issue was.. did the tappets (they weren't massively out), and let it run out of fuel, refueled it and it was fine! Could have been stale fuel.
