ok have a problem here after fitting the new exaust system i have encountered a problem.........
its melted my main power lead from the boot! :'(
the problem is where the LCB fits to the link pipe its a very tight squeese and the cable fouls on the hot system and kindof melts, now iv ordered a new one was thinking becuse it runs inline with the copper pipe for a couple of inches if i can find some way of fitting it to the other side of the copper pipe it would save it.
any other idears?
was thinknig of running it through the car itself?!
thanks guys
re routing the wires
minipip
, Sep 13 2006 01:24 PM
2 replies to this topic
Posted 13 September 2006 - 01:24 PM
Posted 13 September 2006 - 01:41 PM
If your LCB's that close to the battery cable, there's a problem with the LCB..
But there's no reason why it could not go internal, nor moved across the floor pan, you just need to P clip it about every 2-3 inches. Someone with an SVA manual will be able to tell you the exact spacing (still waiting for mine )
Posted 13 September 2006 - 02:04 PM
cheers GW, your a star! well looks like ill just have to do the swap to the other side of the copper pipe and find some way to keep it as far form the zorst as poss!
