Mirror, Sunvisors And Door Check Fitting?
2 replies to this topic
#1 mguk0705
mguk0705
    Just On Tickover
  • 8 posts
Posted 12 December 2016 - 03:36 PM
hi guy and girls
so im 99.999% done rebuilding my thirty from boxes
its taken my 4 years but its on the road
my questions are:
im trying to fit new sunvisors and rear view mirror but its a new headliner and there are on holes and i cant feel and places for holes
i dont want to poke holes through the new liner and guess
any ideas?
also im trying to fit new door checks ive got the checks, rubbers and foam plates?, but ive never seen them on the car as ive built this from boxes so where goes the rubbers and foam things go?
many thanks micheal
#2 mguk0705
mguk0705
    Just On Tickover
  • 8 posts
Posted 12 December 2016 - 03:45 PM
also i may babe pushing my luck but im finding moisture in the car and a small puddle in the driver side floor
now the water mabe fron a dud frame rubber so ive got them on order but im just asking if there is any inherant areas prone the letting in moisture?
as ive said above im yet to fit the door checks as im unsure of correct placement of parts, could this be the place for water entry?
thanks
#3 panky
panky
  • 1,777 posts
Posted 12 December 2016 - 03:56 PM
Start with the mirror first, once you've found one hole then offering the mirror up will show where the others are. Maybe a piece of coloured chalk rubbed over where you think the holes are would show the position.
