84 Mini Mayfair Brakes Bleeding Problems
#16
Posted 02 January 2017 - 05:19 PM
https://youtu.be/7SUyesCy7A4
#17
Posted 02 January 2017 - 05:29 PM
That is very odd. I've never seen that happen before. It looks as though the adjusters are too slack in the backplate - but why?
The inside part of the adjuster is '4-sided' (or should be) so that the adjustment is incremental in 90 degree segments. Once tightened, it self-locks as the adjuster cannot move back through one lobe position after being set to brake-locked position then backed off by one segment.
Have the adjusters been tightened right up until the drum locks then backed off so that it just rotates with some resistance?
#18
Posted 03 January 2017 - 10:22 AM
#19
Posted 03 January 2017 - 11:11 AM
My point it that the lobed shape of the tapered adjuster should mean that once adjusted correctly the adjuster is prevented from turning by the fact that the springs on the shoes pull the shoes onto the adjuster via the little spacer blocks. The shoe cannot move away sufficiently for the adjuster to rotate back because the drum prevents the shoe moving enough for the high point on the adjuster to move back. The adjuster is not meant to be stiff in the thread in the backplate and that is not what maintains the setting. Without any load it should be able to be screwed in by hand. The 4 lobes on the adjuster are what prevents unwanted back-rotation.
You need to see why this is happening. Do the adjustment shafts not have the lobes? Once adjusted correctly with a proper adjuster the adjuster simply cannot unwind - it is held by the lobes on the adjuster. That is how it is designed.
#20
Posted 03 January 2017 - 02:27 PM
#21
Posted 03 January 2017 - 02:42 PM
Posted 03 January 2017 - 03:25 PM
http://www.somerford...oducts_id=16903
#23
Posted 03 January 2017 - 03:33 PM
Sorry, I thought we were talking about the rear brake adjusters - my mistake. The adjustment of the fronts is different on twin-leading-shoe brakes.
#24
Posted 03 January 2017 - 04:31 PM
Haynes just says 'the springs that hold the shoes to the piston - where fitted'. I suspect they are supposed to keep the end of the shoe in contact with the piston to minimise pedal travel, but I wonder how many cars still have them. The brakes seem to work OK without, as yours did.
It's a long long time since I worked on a Mini with front drums but I'm sure there should be a friction plate or serrated washer under the adjuster to keep it tight.
Edit
Just found a diagram in and old Mini maintenance book. There are pins on the ends of the original shoes to locate the little springs, so I guess if new shoes don't have the pins then the springs cant be fitted.
Edited by panky, 03 January 2017 - 05:30 PM.
#25
Posted 03 January 2017 - 06:48 PM
Film of the new master cylinder leaking...
https://youtu.be/t8S3inP53RE
I now think the master is ok, just the backplates on the front being the problem.
I think that the fluid level was excessive after disconnecting the pressure bleeder, the excess was then overflowing via the cap.
#26
Posted 03 January 2017 - 07:02 PM
That was my thought, the brake adjusters therefore should be reasonably stiff to offer some purchase, otherwise the winding back that is happening will always happen.
Mini Spares have offered to refund for them, but I am now worried that I might end up buying another set from elsewhere, but with the same problem. I imagine there are not too many people re-manufacturing these.
I could get another second hand original set off eBay but that seems counterproductive, the idea was to replace with new parts.
#27
Posted 03 January 2017 - 09:00 PM
Not sure if this is any help, but a couple of years ago I bought a set of front drum brake backplates, completely built up with adjusters, cylinders & shoes, from South Lakeland Minis via eBay. Was very handy as I'd managed to round off the adjusters on both sides!
#28
Posted 03 January 2017 - 10:16 PM
I have now created a problem that was probably not there in the first place!
Unfortunately now I only need to replace the backplates as I bought everything else already. If I buy two complete built sets, a majority of this set will be of no use to me. I could resell it I suppose. A bit long winded for such a seemingly simple set up.
#29
Posted 03 January 2017 - 10:42 PM
Sorry - when I said I rounded off the adjusters I meant the square bit on the back, which meant the brake couldn't be adjusted with a spanner any more.
I only bought the complete set as I've heard of problems just replacing the adjusters, add that to the fact the backplates were at least 35 years old and I wasn't too sure about the brake cylinders and I didn't mind paying for them. Kept the brake shoes as spares for future as they weren't too worn.
#30
Posted 22 February 2017 - 11:34 AM
I have sorted this out, the brakes are now perfect all round. The backplate was allowing the adjuster to spin under heavy braking. I have replaced them with another new set, all is fine now. Thanks for your input.
