Jacking Point Advice
Posted 17 December 2016 - 05:34 PM
Posted 18 December 2016 - 09:01 AM
I'm fitting genuine ones to mine as I'm going for originality and to be 100% sure its strong incase I ever have to jack the car. Although I've had the car 14 years, I don't think i've ever jacked it up using the jacking point...
Posted 18 December 2016 - 02:48 PM
I use the M Machine ones and never had an issue with them being unable to jack the car on.
Posted 18 December 2016 - 07:31 PM
Posted 18 December 2016 - 08:16 PM
I never really liked the look of the mini jack so never used one
I think I'll try M Machine.
Thanks for the replies
Posted 20 December 2016 - 12:00 PM
The jacking point, situated where it is and tying together the central crossmember and inner and outer sills, makes a significant contribution to the torsional stiffness of the shell. So if you want the best possible handling and longest shell life for a given set of mechanical parts, always fit the jacking points. There is also some advantage in retaining the shell slinging brackets, for much the same reason, only the effect is less, but the pads under the floor are pointless and serve as a temptation for inexperienced tyre fitters etc to use as jacking points and bend the floor. You could close the hole in the outer sill but still have an internal stiffner, plug welded to the outer sill, to keep the stiffness if you really don't want a jacking point for aesthetic reasons or to try to reduce corrosion.
I wonder about fitting jacking points fore and aft instead of the slinging brackets, so you could jack one wheel up instead of both? Might need a bit of work...
Some people on here are nervous about using the jacking points. If your shell is correctly maintained and restored, they are fully adequate. If your shell is a heap of rust, beware...
Posted 20 December 2016 - 01:49 PM
From what I remember though, they are expensive for something you don't see, so I made mine, as below.
IMG_0068.JPG 79.64K 6 downloads
IMG_0100.JPG 38.41K 8 downloads
When the sill went on, I swam welded the tube to the opening in the sill, to stop water ingress and to add strength.
Edited by NuFab, 20 December 2016 - 01:52 PM.
