how do u toe wiv no toe eye?
Posted 13 September 2006 - 06:48 PM
Posted 13 September 2006 - 06:50 PM
Posted 13 September 2006 - 06:52 PM
i raped the tow rope round my front subframe today
were bouts on the subframe?? was looking 4 a while earler coulndt really see a good place
Posted 13 September 2006 - 06:54 PM
Edited by minipip, 13 September 2006 - 06:55 PM.
Posted 13 September 2006 - 07:10 PM
i took the grill off you can see better that way feed it under then up between the gearbox and the subby then down between the front valance and the subby then just clip it to itself, rember to keep the tension whn towing!
big job then? no other place thinking 2 bars coming off the wheels onto two bolts behind the bumber? as i have to tow it half 5 in the morning
Posted 13 September 2006 - 07:32 PM
Posted 13 September 2006 - 07:35 PM
just wrap it round the front of the subby. only way without a toe eye
Posted 13 September 2006 - 07:36 PM
i wrapped a tow rope around the front subframe meamber. i suggest taking the number plate off 1st tho.
just the front number late? is it in front of the sump?
Posted 13 September 2006 - 08:29 PM
If you need a toe eye, you can go down to a local b&q or hardware place and buy one or more bolts with a ring on the end, the ones I got from b&q came as a pack of 4 fence bolts and used 17mm nuts so were more than beefy enough.
Only thing was they were an open hook and so need welding slightly, just in case the loop was to ever stretch and deform causing the rope to fall off etc, while towing.
All I did then was remove the 1/2" nut bolt that goes through the front valance, through the tear drop mount and into the sub frame and replaced with the new bolt after I cut it down to a more suitable length, nut wound on first to set distance to poke out of the valance, then a big penny washer, poked through the subframe and then a washer and the other nut on the other end.
Been fine so far although I don't plan on using them that often.
Posted 13 September 2006 - 08:58 PM
does any 1 no how to toe a mini wiv no toe eye? thanks
Any chance of also typing in what is commonly known as ENGLISH ??? :'(
Posted 13 September 2006 - 10:36 PM
Posted 13 September 2006 - 10:40 PM
Posted 14 September 2006 - 09:10 AM
Posted 14 September 2006 - 12:48 PM
Posted 14 September 2006 - 01:43 PM
