I had a previous thread here which is titled Hard Gear Selection
anyway it was hard to select all the gears except reverse
I tried adjusting the clutch and followed this procedure
http://members.tripo...erica/id68.html
and it made the gear shifting impossible, it wont even go in the gear gates and pedal feel is very different there's no feel of fluid pushing if you know what I mean.
Then I unbolted the throwout stop nut maybe with 2mm - 3mm gap between the clutch cover and I can shift the gear better now. But still hard to change from neutral to 1st gear but can easily be change by going to 2nd then 1st.
here's a pic of the throwout stop nut with the gap
sorry about the flash, it was getting dark
Clutch Adjustment Issue
Razor
, Sep 14 2006 09:19 AM
2 replies to this topic
Posted 14 September 2006 - 09:19 AM
Posted 15 September 2006 - 02:16 AM
advice anyone?
Posted 15 September 2006 - 08:20 AM
There's a thread somewhere recently which I described the process for setting the clutch throwout... but basically sounds like you're not getting enough mvement on the clutch arm, advise bleeding the clutch system first, then setting the clutch throw out, and adjustment, then seeing what happens.
