On my way to work this morning, my mini made a grinding noise, then died.
As I lifted the clutch in fourth the engine seemed to struggle, then it stalled. After pulling over, the engine started first time, the gear selector feels like it's engaging, but when I release the clutch it stalls again, as though the diff has seized.
Can anyone tell me if this sounds like the diff has gone?? And if so whats involved in sorting it.
Cheers,
FG.
Has my diff just died??
TheFunkyGibbon
, Sep 14 2006 09:20 AM
4 replies to this topic
Posted 14 September 2006 - 09:20 AM
Posted 14 September 2006 - 10:06 AM
when my diff went bang it went through the gear box so it was easy to spot
lots of metal bits under the car and a big pool of oil :'(
Posted 14 September 2006 - 10:28 AM
the usual indication is a big hole in the diff casing an oil everywhere... but if not..
But as you seem to be able to move the car then the diff's not locked, and is still turning.
What may be the problem is the main bearing in the gearbox has collapsed, this will cause the gearbox to lock, but will allow selection of gears...
Other options are the idler gear has blown, and has bits jammed into the primary gear (less likely)
But what ever the case, it's an engine out by the sounds of it...
Posted 14 September 2006 - 11:20 AM
When I was pushing the car (from the tow truck) it did lock up, but with a bit of rocking back and to, it released again....would this point to the bearing then?
Edited by TheFunkyGibbon, 14 September 2006 - 11:20 AM.
Posted 14 September 2006 - 11:29 AM
Certainly very similar symptoms to one I had go on me a few years ago
