Noise coming from the front end
Posted 14 September 2006 - 09:36 AM
I noticed this before when I bought the mini, I was thinking before might be just the brake pads...
but today I drove the mini down the road to test and it sounds more like a squeeky rubber/tyre fouling something, but had a good look under and the wheels/tyres doesnt hit anything or anything close to it to make such a noise.
The noise is always there more evident when slowing down or rolling the car like on 15+kph
just wondering if you can tell from this pic if my pad is worn out from this pic...
Anyone had the same issue before? what can be worn out or something wrong with the mini?
Posted 14 September 2006 - 09:57 AM
This is probably totally irrelevant but a failing water pump can make such a noise at the roadspeeds you describe. Have you definitely tracked the noise to the wheel?a squeeky rubber/tyre fouling something
Posted 14 September 2006 - 10:14 AM
its defintely coming from the wheels
knuckle joint? drive shaft loose? can these parts make this type of noise/
Posted 14 September 2006 - 11:11 AM
The wheels are always clear of arches etc when turned lock to lock?
Posted 14 September 2006 - 11:23 AM
Posted 14 September 2006 - 12:38 PM
Or bushes gone in suspension?
Edited by TOMMO0302, 14 September 2006 - 12:38 PM.
Posted 15 September 2006 - 02:17 AM
Posted 15 September 2006 - 04:10 AM
the noise is in synch with the wheel revolving the noise goes faster when the wheels/car is moving faster
Posted 15 September 2006 - 08:55 AM
The practice of doing this is not ideal, but I am a nutter and will try anything once until it goes wrong.
Disclaimer: I will not be held responsible for any damage caused due to unsafe procedures. You do all of the above at your own risk
Other than that, TAKE IT TO A GARAGE
Posted 15 September 2006 - 09:03 AM
What it could well be are the rubber cones shifting inside the subframe perhaps, this could create a squeaking much like a tyre would, knuckle joints could also create some strange sounds.
Posted 15 September 2006 - 09:19 AM
"It turned out to be rust on the discs (rotors). You say that there is rust on the edge but not on the faces. The centre of the disc will almost certailny have rust as well, where the flange joins the disc and on mine this had spread a little so that the inner edge of the pad rubbed on it when the wheel was rotating"
I'll take photos of the disc tomorrow and post it here
Posted 15 September 2006 - 03:05 PM
Posted 15 September 2006 - 11:08 PM
more like tyre rubbing noise but the wheels are not fouling anything
its clear
Posted 17 September 2006 - 10:01 PM
mines not really squeeky like when you have problems with belts
its clear
Did you manage to fix it?
