Posted 02 January 2017 - 07:20 PM
Posted 02 January 2017 - 08:24 PM
As mentioned yesterday it's the air valve, or air valve diaphragm. When operated this valve allows air onto one side of the main diaphragm, on the other side of that diaphragm is a partial vacuum from the inlet manifold. Push the brake pedal and the internal piston pushes the air valve open allowing atmospheric pressure to act on the main diaphragm and gives the brake assist. If the air valve is passing then there is constant pressure on the main diaphragm when the engine is running - remove the vac line and the pressure is equalised so the brake assist is removed.
Hopefully this will explain your problem, wont help with parts availability though
Edited by panky, 02 January 2017 - 08:38 PM.
Posted 04 January 2017 - 09:12 PM
If you've got a strong right leg you can run a Mini on 7.5 inch discs using road pads and still lock up the front brakes in the dry.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Occasionally Spongy Brakes (96 Spi)Started by TeddytheSpoon , 01 May 2025 ![]() |
Converting To Yellow Tag Brake Master CylinderStarted by Nickj270386 , 29 Apr 2025 ![]() |
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
Brake Servo And Lack Of Brake PedalStarted by Moose94 , 14 Mar 2025 ![]() |
