Upper Arm Nut Spinning On Suspension Reassembly?
suspension
3 replies to this topic
#1 kiwiminime
kiwiminime
  • 25 posts
Posted 04 January 2017 - 03:06 AM
Hi all,
I've managed to upgrade all of my front bushes and am trying to put everything back together.
For some reason the upper arm nut is spinning with the thread attached to the ball underneath... making it pretty much impossible to tighten.
Any tips?
I'll attach a photo below:
Attached File  IMG_2834.jpg   36.65K   30 downloads
#2 timmy850
timmy850
  • 3,345 posts
  • Local Club: MITG
Posted 04 January 2017 - 03:13 AM
Make sure the thread is nice and isn't damaged as that will make it grip and turn like you say. You can also put pressure up from the bottom to force the taper of the ball joint into the suspension arm which might stop it spinning.
#3 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 04 January 2017 - 09:31 AM
As above, make sure the threads are clean and then gently jack the hub up under the bottom ball joint; this will jam the taper into the upper arm.
#4 tiger99
tiger99
  • 8,584 posts
Posted 04 January 2017 - 03:09 PM
As above. I use a jack underneath, but have had success in similar situations by levering against the arm to pull the partially fitted nut upwards to engage the taper more fully. There are tricks with G clamps and even on some cars, valve spring compressors, but on the Mini these will only fit the track rod end, where a similar problem exists. Modern track rod ends may have a socket for an Allen key to prevent rotation while you nip them up with a spanner, but I have yet to see that sensible innovation on the Mini ball joints. Not easy and cheap to manufacture.
But as can be inferred from previous suggestions, you only need to get the taper pushed together moderately tightly (having taken them apart you will know how tight they grip!) and anything suitable that you have to hand will do.
But please check that some moronic parts supplier has not given you metric nuts for a UNF thread. It is not unknown, and it is even more common on the driveshaft/hub nut.
Oh, and as you are likely to have the same problem with the bottom ball joint some time in the future, the trick is similar, just jack under the arm where it meets the tie bar, until it is taking a portion of the car's weight on the taper.
You can use a ratchet strap around top and bottom arms on some cars. Never tried it on a Mini.
Have fun!
Edited by tiger99, 04 January 2017 - 03:10 PM.
Also tagged with one or more of these keywords: suspension
