Sae Vs Imperial
17 replies to this topic
#1 J6collins
J6collins
  • 64 posts
Posted 06 January 2017 - 06:58 PM
Anyone know if there is a difference? My 77 mini should need imperial tools correct? Will SAE or metric tools work instead? Thanks
#2 Spider
  • 15,238 posts
Posted 06 January 2017 - 07:34 PM
SAE (Society of Automotive Engineers) is generally Imperial Sizes.
#3 Ethel
  • 26,159 posts
Posted 06 January 2017 - 07:43 PM
Minis are mostly held together with UN threads, which need imperial sized tools.You do find other thread forms, like some brake hydraulic unions.
#4 J6collins
J6collins
  • 64 posts
Posted 06 January 2017 - 08:07 PM
I cannot get this brake line out! the wrench wants to strip the bolt. The bolt won't budge. Any help would be grest
#5 Spider
  • 15,238 posts
Posted 06 January 2017 - 08:17 PM
That particular one is 10 mm AF.
As Ethal has eluded to, while most threads and fittings on the Minis are Imperial, there are some Metric ones and some (not all!) of the Brake Line Fittings fall in to this category.
In regards to getting that Union undo, on advice from PBR a Brake component manufacturer, they recommend using Vice Grips. Better to mark it than round it off, BUT go easy since they are hollow, it's also easy to crush it.
#6 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 06 January 2017 - 09:34 PM
Use a proper brake spanner or flare nut spanner as they grip the nut better. Soak some penetrating fluid on it and where the pipe goes into the union as that is where they usually grip up and then try gentle tightening it to break the nuts grip and then rock it backwards and forwards to try and loosen it. They do usually come free the other thing you can do before the nut gets rounded is cut the pipe and put a socket on the nut as that grips on all sides. This will mean you will have to replace that run of pipe. Good luck
#7 tiger99
tiger99
  • 8,584 posts
Posted 06 January 2017 - 09:35 PM
In cases where things may have changed since 1959, it doesn't hurt to have both metric and A/F spanners handy and use the one that fits properly each time. Better that than skinned knuckles or severely impaired bolt heads that are going to take ages to remove.
#8 J6collins
J6collins
  • 64 posts
Posted 06 January 2017 - 09:41 PM
Thanks for the help everyone. I'm letting some wd sit over night, maybe that will losen it up. 7/16 fits best 10mm does not fit at all. Maybe better luck in the morning
#9 jakejakejake1
jakejakejake1
  • 644 posts
Posted 06 January 2017 - 09:50 PM
7/16 is just over 11mm (11.11mm), so an 11mm might fit slightly better if you can get it on.
It's worth investing in a set of calipers so you can measure things like nuts, helps to get the tightest spanner on possible especially if the nut is stuck.
#10 nicklouse
  • 18,751 posts
Posted 06 January 2017 - 10:13 PM
WD40 is not a penetrating fluid. If you were in the UK I would say PlusGas. Not found comparable in Germany yet.
Which bolt/nut are you having issues with?
#11 Dusky
Dusky
  • 5,322 posts
Posted 06 January 2017 - 10:23 PM
Good brake line spanners are a gift from God. :)
#12 gazza82
gazza82
  • 3,026 posts
  • Local Club: TMF+
Posted 06 January 2017 - 11:40 PM
WD in WD40 stands for water dispersant. Nuff said ...
Plenty of proper penetrating fluids around.
I wonder what the WD40 branded version actually contains? Or their silicon spray?
#13 J6collins
J6collins
  • 64 posts
Posted 07 January 2017 - 07:48 PM
Ok finally got it out after hearing it with a torch. Finished my brake job but still a little squishy, I'll finish the job tomorrow. Took the car for the first test drive ever! Love the car now but the clutch went out half way through the test drive..... anyone know what would cause this?
#14 J6collins
J6collins
  • 64 posts
Posted 07 January 2017 - 07:55 PM
What I mean by it went out is that there is no pressure at all. I left with no issues while I was driving the clutch just went out
#15 Alice Dooper
Alice Dooper
  • 391 posts
  • Local Club: Minis in Northern Ireland
Posted 07 January 2017 - 10:08 PM
WOW a torch on a brake fitting!! Your braver than me. Hydraulic fluid, even vapours are the most flammable thing in a car. Glad it worked out. Echo the calipers. I bought a wee digital set at £9, easy read and converts imperial / metric at touch of a button. Well worth it.
