Hi,
I'm in the process of cutting out rust at the moment and wanted to know
1) Regarding the rear mounting of the rear subframe, how, exactly is the body in that area made up? I can see the stiffener that connects to the wheel arch but under that all I have is rust :'(
2) I am looking at getting a couple of lower front windscreen replacement corners. In that area that the windscreen rubber fits onto, how is that 'lip' made up? It's just that the area at the top of the inner wing under the scuttle end is rusty and needs sorting and it looks like it connects up there somewhere!!
I hope I've explained this well enough
Cheers,
Spud.
Two simple questions.
spud
, Sep 14 2006 05:57 PM
5 replies to this topic
Posted 14 September 2006 - 05:57 PM
Posted 15 September 2006 - 11:15 AM
hiya mate,
Not sure what you mean in question 1 but as for Q2 I would replace the whole of the scuttle panel rather than just the corners. It'll be alot easier than cutting out the corners, welding them back and smoothing
Adam
Adam
Posted 15 September 2006 - 11:50 AM
Thanks for that ! I'll bear that in mind.
With reference to Q1 I have had another look and am guessing that the rear subframe rear mount fixes onto 3 layers in total. The top layer (under the fixing bolt head) is the strengthener, the second layer is the boot floor skin but I can't make out what the bottom layer is -any ideas?
I have to replace the subframe so I might be able to see it better with it removed
Cheers,
spud.
Cheers,
spud.
Posted 15 September 2006 - 01:07 PM
No idea sorry. Mine is a little rusty around the bracket but the bracket itself is fine. I've just replaced my subby, radius arms etc - I bet you'll need new shocks too.....then you'll decide you need hi-los.....
Posted 15 September 2006 - 07:12 PM
I feel better already
Where's the cheapest place to get a rear subframe at the moment? a pattern one will do!!
Cheers,
spud.
Cheers,
spud.
Posted 15 September 2006 - 07:26 PM
I REALLY would spend a little more and get a genuine one. I'd take it all apart and inspect everything then take a trip to Minispares with a full list. If you get the parts that you think you need before taking everything apart you will be constantly hounded by needing new bits to replace those that are knackered.
