Rear Wheels Rubbing On Arches
17 replies to this topic
#16 nicklouse
  • 18,615 posts
Posted 16 January 2017 - 10:23 AM
I had this problem also. Everyone would say "your car is obviously too low" when it wasn't. I tried stiffening the dampers to maximum and no change. In the end the cure was to fit a rear anti-roll bar. It worked a treat!! I used a KAD one as the rest on the market look crap! Hope this helps.
An anti roll bar will not help if your ride height is too low or your springs are too soft.
Having had exactly the same issue as the this guy, I can assure you it does!! It may not be what an anti-roll bar is designed for, but it solved the problem. I can even soften my dampers right off so I get a decent ride quality.
can not help with the original posted issue. it can help in cornering by transferring the spring force from the inner side but in a compression there is nothing to transfer as both wheels are moving together.
#17 Robdavmtb
Robdavmtb
  • 29 posts
Posted 19 March 2017 - 11:54 AM
Managed to get some photos today. As you can see it's not really low but still doing it.
#18 Robdavmtb
Robdavmtb
  • 29 posts
Posted 19 March 2017 - 12:00 PM
