Conversion From Spi To Carb ... No Spark
Best Answer Kholden , 30 January 2017 - 07:40 PM
Thank you everyone for your input. The problem has now been sorted...faulty module
Go to the full post
Posted 22 January 2017 - 06:48 PM
Posted 23 January 2017 - 09:19 AM
Posted 23 January 2017 - 09:24 AM
Posted 23 January 2017 - 01:33 PM
Posted 23 January 2017 - 01:37 PM
Posted 23 January 2017 - 06:17 PM
Posted 23 January 2017 - 06:29 PM
Have a look inside the dizzy cap and see if the little carbon plunger is there - one disapeared on me once
Posted 24 January 2017 - 06:38 PM
Posted 24 January 2017 - 11:10 PM
Posted 25 January 2017 - 01:19 AM
immobiliser? Pages 447, 460 and 461. The white wire coming from the ignition switch should go now to the + of the coil not a brown pink which would come from the ECU. The electronic distributor probably has to have power from the same white wire for the electronics to operate.
http://miniscene-unt...anual_92-96.pdf
Posted 27 January 2017 - 08:19 PM
Posted 27 January 2017 - 10:16 PM
Posted 28 January 2017 - 01:23 AM
Posted 28 January 2017 - 01:26 AM
Posted 30 January 2017 - 07:40 PM Best Answer
Also tagged with one or more of these keywords: electrical, engine
engine
Mini Technical Sections →
Problems, Questions and Technical →
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , Yesterday, 08:11 AM ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
