Holes In A Bonnet - Finishing
28 replies to this topic
#16 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 29 January 2017 - 08:25 PM
The problem with that is you will be left with the mounting holes visible.
Maybe panels you can swap out.
 I could live with the visible fasteners.
#17 splintercat
splintercat
  • 616 posts
Posted 02 February 2017 - 06:09 PM
I did something similar a while back, cut the holes with a 50mm cutter and then on theback of the holes I used a fine wire mesh bonded to the bonnet to stop too much crap getting in, the best mesh that I found and it was cheap too was the stuff from Halfords which you would use for fibrelass repairs, was about £2 for a piece the size of A3 paper.
#18 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 05 February 2017 - 06:54 PM
So thinking about cutting two ovals like this mini
Screen%20Shot%202017-02-05%20at%2019.49.
mocked up some cardboard
6882E922-F68E-4ABC-90E5-95652A553028_zps
A095E7C4-4CBF-4913-A3EE-9741EF2714A8_zps
I have spoken to arc angels who will make a FG panel the shape of the bonnet. I thought it would be a good idea too use this in bad weather.
Something this shape, but fitting the count ours of the bonnet
1B088F5B-A480-49F2-84A6-338102E06DDF_zps
#19 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 05 February 2017 - 07:44 PM
How about this?
Behind the aluminium panel there's just a row of four holes slightly larger than the outer ones.
Attached File  image.jpeg   22.65K   7 downloads
Looks neat enough ;)
#20 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 05 February 2017 - 08:43 PM
picture from facebook, this was a car at Bingley, seems to have holes then they have been dimpled. not the right position but could work?
16473350_10210335627400293_3719090542297
#21 nicklouse
  • 18,763 posts
Posted 05 February 2017 - 09:51 PM
Can't dimple fiberglass.
#22 splintercat
splintercat
  • 616 posts
Posted 06 February 2017 - 01:30 PM
Just gotta love that word "Dimpled" :proud:
#23 Midas Mk1
Midas Mk1
  • 5,796 posts
  • Local Club: S.U.N.M.C
Posted 06 February 2017 - 01:37 PM
Think 'Swaged Hole' has got more swag though   :D  :lol:  ;D
#24 monkey
monkey
  • 1,382 posts
  • Local Club: Diss Mini Club
Posted 17 February 2017 - 04:31 PM
If you are going to have a removable panel for bad weather, why not mount it on the inside? That way when the panel is off you will see nothing off it just the holes, no mountings / fasteners?
#25 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 18 February 2017 - 10:38 AM
That is a good idea!
I have ordered a panel from arc angels who will mould it to the contours of the bonnet.
I had thought of using Dsuz fasteners, but I haven't quite thought through exactly how.
With the panel on top as I had thought it will look fine with the panel on (with the dsuz closed), but not so good with the panel removed I.E non finished holes.
Anyone have any other tips for fasteners?
#26 nicklouse
  • 18,763 posts
Posted 18 February 2017 - 11:32 AM
to be honest I think you will end up with just cutting a big hole and have two different panels. One in alloy with swaged holes is it. And the other being the closing carbon panel.
Or you revers fit the Dzus fastners and have the panel fitted to the inside. But that will reduce internal space.
#27 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 23 April 2017 - 06:26 PM
A bit of an update on the bonnet hole and cover panel also. I cut two holes in the front of the bonnet and had a panel made up by arc angels to match the contours of the bonnet, the i sea is I can use the panel in bad weather to keep all the muck out.
I will add a thin rubber edge trim/seal on the holes. Which will cover up any unevenness (in my cutting and the changing thickness of the fibre glass).
D413944B-B26B-4F18-9907-7DF9B9C26B71_zps
923E3DC2-7978-4D26-89E3-7EA28D711DDE_zps
948BFFB2-0526-4E5F-AABF-3FA231D928AF_zps
The panel is held on with two quarter turn "Camloc" fasteners. Really nice little things. The panel itself I think I will leave without a rubber edge trim.
D400232F-01EA-4C7E-B707-9479110BCC7C_zps
B5ACFF00-08EF-4DC3-8B1B-6340802FF7ED_zps
70D5C434-5FBF-4CAB-9C61-EDF1EFE92B27_zps
A quick test drive  the improved air flow, really felt like it made a big difference.
#28 sixtyeight
sixtyeight
  • 630 posts
  • Local Club: forums.minidriver.com.au
Posted 03 May 2017 - 09:05 AM
looks great, and very period!
#29 CobraV8
CobraV8
  • 991 posts
Posted 16 May 2017 - 09:03 AM
Weld the pipes to a flat piece of alloy sheet bent to fit the bonnet. Glue that piece to the inside of the bonnet.
