Help please...
So I think the heater matrix on my 1999 MPI needs replacing, as coolant just poured out into the centre console and steam filled the car via the windscreen vents!
My questions are:
Is there anything else it could be/I should check first?
If it is the matrix, do I have to drain all the coolant (from the rad bottom hose) first, do I need to remove the heater as a whole (which also entails removing the centre console first) or can I get to the matrix with the heater in-situ??
Answers and any other tips/advice much appreciated! TIA.
