B-Pillar > Rear Hoop Measurement
Posted 01 February 2017 - 07:35 AM
Unfortunately I don't have the luxury of having an engine available currently to mock up the rear hoop location, hence the question.
Any help would be greatly appreciated!
Posted 01 February 2017 - 08:32 PM
Hi, Im guessing you have already cut the body out but are looking for the exact mounting position of the base plate for the main hoop. I positioned mine by measuring where the front of the cage frame met the floor in the footwell with the upright right up against the lower dash board rail. If you put it as far forward as this the rear wheel sits pretty much where the original did. Hope this helps
Posted 01 February 2017 - 08:55 PM
I've been through various builds and it looks somewhere between 100-200mm offset from the b pillar but a quick snap with a tape measure next to the gap would be grand if anyone's got one.
Thanks for the response though.
Edited by KaneH, 01 February 2017 - 09:05 PM.
Posted 02 February 2017 - 07:11 PM
Posted 03 February 2017 - 10:19 AM
http://www.theminifo...hell/?p=2669739
A search for 'Floor Cut' threw this up.............you should be able to reverse engineer from that......
Posted 06 February 2017 - 04:41 AM
Posted 08 February 2017 - 11:09 AM
The Dropbox link doesn't work.
I was referencing the post from Benmoffat.... not my dropbox so cant help there.....
Posted 08 February 2017 - 12:46 PM
Posted 08 February 2017 - 03:21 PM
