Mini Seems To Hold Onto Revs To Long
13 replies to this topic
#1 ClassicAsh
ClassicAsh
  • 139 posts
Posted 06 February 2017 - 07:55 PM
My mini cooper Spi seems to run well but I have noticed that it seems to hold onto the revs to long, by that I mean if you come of the throttle the revs seems to stay at around 2000 rpm for four or five seconds before dropping down to the normal idle speed of approx. 1000 rpm. all the vac pipes are new and a good fit, and the engine has been refurbished. am I missing something simple? any ideas? thanks.
#2 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 06 February 2017 - 07:56 PM
Throttle linkage adjusted?
#3 pusb
pusb
  • 1,216 posts
Posted 06 February 2017 - 08:00 PM
Throttle cable sticky?
#4 ClassicAsh
ClassicAsh
  • 139 posts
Posted 06 February 2017 - 08:08 PM
the throttle cable sees to be fine in operation  having had an assistant operate it while I watch and the linkage sees ok to operate ok too.
#5 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 07 February 2017 - 12:33 PM
this might be something to do with a leaking vacuum/breather pipe. Think ive read it before elsewhere. might be wrong though. typical for mpi/spi modles
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 09 February 2017 - 01:19 AM
Throttle cable adjustment maybe. see pinned topics.
Edited by Sprocket, 09 February 2017 - 01:19 AM.
#7 domdee
domdee
  • 1,183 posts
Posted 10 February 2017 - 12:43 PM
http://www.theminifo...st#entry3225242
#8 ClassicAsh
ClassicAsh
  • 139 posts
Posted 15 February 2017 - 03:04 PM
had a good poke about and everything seems ok cable seems to run in the correct place and isn't sticking, and all the breather pipes are new including the elbows etc. hmm another head scratcher ! but thanks for the reply's all
#9 brivinci
brivinci
  • 1,210 posts
Posted 21 February 2017 - 04:12 PM
This seems to be becoming a common issue with these. I have the same issue and have read a few threads over the years related to the same issue. Mine drops to maybe 1500 for a second or two (could be more) and then finally settles at the correct idle speed. All of my vac lines were replaced with proper silicone replacements to avoid the originals easy fail rate. My cable is fine as well. Everything seems to move as it should. Manually pulling back throttle pedal when this happens does not bring the revs down any quicker.
I do remember reading a thread where someone took apart there throttle body and found that a seal for (maybe) the butterfly shaft was torn and causing some erratic running/idle conditions.
#10 brivinci
brivinci
  • 1,210 posts
Posted 21 February 2017 - 04:15 PM
Nice thread. Thanks!
#11 FlyingScot
FlyingScot
  • 2,664 posts
Posted 24 February 2017 - 12:52 PM
Check your TPS for smooth changes. It's a potentiometer and wears causing a noisy signal and/or a dead spot.
You can either measure on volts by backprobiing the connector or in plug and measure on ohms between the centre and outer pins.
This can confuse MEMS as it needs the output to tell the throttle pedal is at idle (first versions used a switch to do this)
FS
#12 brivinci
brivinci
  • 1,210 posts
Posted 24 February 2017 - 04:57 PM
I think this is the next thing I am going to do. Thanks FS
#13 ClassicAsh
ClassicAsh
  • 139 posts
Posted 24 February 2017 - 10:23 PM
I will give the suggested things a try this weekend and see what happens. thanks all
#14 Alpenflitzer
Alpenflitzer
  • 396 posts
  • Local Club: no
Posted 25 February 2017 - 11:50 AM
Cold: rpm 1200    warm= 850 rpm so it is told by the "Repairbook".
Have you checked this one?
