Lights, again!
Feeble
, Sep 16 2006 12:52 PM
12 replies to this topic
Posted 16 September 2006 - 12:52 PM
My lights have stopped working for the second time in the last month!
They first broke the other week, so I took the switch out, and the white connector bit had brown burn marks on it. The switch was also a tiny bit melted at the back. So I changed the switch and it all started working fine again.
Now, the exact same thing is happening - the switch is starting to melt a little around the middle pin!
Help please MOT on Monday!
Posted 16 September 2006 - 12:58 PM
What bulbs have you got in your headlights? Sounds like you need to relay them.
Posted 16 September 2006 - 01:16 PM
I don't know! The wires in the connector are all a bit burned as well! How hard is it to replace the connector?
Posted 16 September 2006 - 03:56 PM
Fix the problem...not the symptom !!
Check the bulbs fiirst !!!
Posted 16 September 2006 - 04:03 PM
Ok, so what am I looking for, blown bulbs? Or the wrong type of bulbs?
Posted 16 September 2006 - 04:06 PM
Wrong type of bulbs. Any higher than 60Watts and they could be drawing too much current through the standard headlight wiring and switches.
Either reduce the wattage of the bulbs or re-wire the system using a relay !
Posted 16 September 2006 - 04:09 PM
Rewire?! I'll check the bulbs and hope to God that they're wrong!
Posted 16 September 2006 - 11:02 PM
Have you got any extra sidelights fitted? Have you got halogen headlamps? Is the wiring corroded at the terminals? The lighting circuit runs very close to the maximum safe rating of the switch and so anything which causes it to draw extra current melts the bugger. It runs 14.7 ish amps as standard and the switch is rated at 16 so its easy to overload it. That then causes the wiring and connector to melt. The best solution is to relay the headlamps which has been covered many times before in great depth (as has this whole problem). Search the site.
Posted 17 September 2006 - 12:27 AM
Thanks Dan, will do!
Posted 17 September 2006 - 10:40 AM
also check the connector under the bonnet catch
Posted 17 September 2006 - 10:50 AM
disconnect the resistor by the rad, and check fuse and connections behind grill as could be becaus eof high resistance
dave
dave
Posted 23 September 2006 - 04:16 PM
Just had a look at my lights, and I have got 60W halogen lights... Could this be the problem?
