Kent Kc152142 Valve Springs?
Posted 22 February 2017 - 04:42 PM
Got them fitted with a 286 cam but getting valve float so not sure if it's valve springs or incorrect fitted length..
Posted 23 February 2017 - 08:19 AM
Posted 23 February 2017 - 08:24 AM
Call Kent?
to be honest not valve spring numbers I recognize.
Posted 23 February 2017 - 08:35 AM
I believe they are the outer spring of the VS2 double spring set.
The VS2s should be fine on a 286
Posted 23 February 2017 - 08:50 AM
http://www.kentcams....ing/VS2-Double/
Posted 23 February 2017 - 08:56 AM
Posted 23 February 2017 - 05:52 PM
The Minispares valve springs come with comprehensive instruction leaflet, this gives the maximum recommended installed height for the valve springs. If they are above recommended height then you need to use shims under the valve spring to get correct poundage.
Do the Kent valve springs not come with similar instructions?
Posted 23 February 2017 - 06:13 PM
Yes see link above.The Minispares valve springs come with comprehensive instruction leaflet, this gives the maximum recommended installed height for the valve springs. If they are above recommended height then you need to use shims under the valve spring to get correct poundage.
Posted 23 February 2017 - 06:51 PM
Thanks Nick, I should have checked the link.
Looks like the recommended installed heights for Kent VS2 (36mm) and Minispares C-AEA526 (1.42 inch = 36.07mm) valve springs are almost identical.
Posted 23 February 2017 - 07:15 PM
Posted 23 February 2017 - 10:44 PM
I use a digital vernier caliper, reads to 0.01mm
To hold the valve cap up either use the inner spring, or one of the rocker shaft springs also works and is easier to fit for measurements.
Posted 23 February 2017 - 10:48 PM
Posted 24 February 2017 - 09:53 PM
If any of the valves have been replaced you may find installed spring heights for the inlet and exhaust valves are different, even if all of the valve stem tips are all at exactly same height.
A reason for this variation can be the distance of the collet retaining groove from valve tip can vary. On one head I had a difference of 1.5mm between inlet and exhaust installed spring heights because of this .
Posted 25 February 2017 - 10:19 AM
Surely I shouldn't get valve float at 5000rpm with the correct springs in..
Posted 25 February 2017 - 02:39 PM
