Kent Kc152142 Valve Springs?
47 replies to this topic
#16 mini-geek
mini-geek
  • 1,169 posts
Posted 25 February 2017 - 03:17 PM
The valve doesn't shut in time for the next cycle
#17 Allrounder
Allrounder
  • 188 posts
  • Local Club: Hereford Motor Club
Posted 25 February 2017 - 05:01 PM
And what's the effect you getting because of this as it's not something I've experienced before?
#18 carbon
carbon
  • 2,590 posts
Posted 25 February 2017 - 07:01 PM
Interesting they are all within 0.5mm of 36mm I can't see that causing insufficient spring compression..
Surely I shouldn't get valve float at 5000rpm with the correct springs in..
Are you using both inner and outer valve springs from the VS2 set, or just the outer?
#19 mini-geek
mini-geek
  • 1,169 posts
Posted 25 February 2017 - 07:50 PM
Both
#20 carbon
carbon
  • 2,590 posts
Posted 25 February 2017 - 08:12 PM
Strange, would have thought the VS2s would allow over 7000rpm even with 286 using high lift rockers.
Is there anything else fitted which might give similar(ish) symptoms, such as a rev limiter?
#21 Swift_General
Swift_General
  • 871 posts
Posted 25 February 2017 - 08:24 PM
Why do you think you're getting float?
#22 mini-geek
mini-geek
  • 1,169 posts
Posted 26 February 2017 - 09:10 AM
Tuner/mapper has confirmed it
#23 Allrounder
Allrounder
  • 188 posts
Posted 26 February 2017 - 09:58 PM
So I take it that the engine is missing over 5000 rpm. How did they come to the conclusion that it is the value springs?? Did they use a oscilloscope!
Think the only way to be sure is to check to poundage of the springs you've got, but then you need to know what they should be. Would of thought in the area of 180 to 200 lbs but Kent cams should be able to give you that information.
#24 mini-geek
mini-geek
  • 1,169 posts
Posted 26 February 2017 - 10:06 PM
The guy is very experienced I have no doubt over his diagnosis.
But what else could it be.. it's a popping crackling noise at high RPM and the power dips off as it happens.. it runs fuel injection it has fuel it has spark so the only thing missing is compression..
I'm planning to put in 280lb springs I know they are a tad high but for the limited use it gets and the type of driving, I also like to be able to rev an engine I think it will be fine.
#25 nicklouse
  • 18,999 posts
Posted 26 February 2017 - 10:21 PM
All the valve specs are in the product brochure
Installed pressure. Max pressure , installed height.bind etc etc
http://www.kentcams.... catalogue 2016(7).pdf
http://www.kentcams....atalogue 2016(7).pdf
Crap links.
http://www.kentcams....lly/#fragment-1
Link on the right.
Edited by nicklouse, 26 February 2017 - 10:22 PM.
#26 mini-geek
mini-geek
  • 1,169 posts
Posted 26 February 2017 - 11:15 PM
Sorry what information am I looking for?
#27 Northernpower
Northernpower
    Mr. 7-Port
  • 2,414 posts
  • Name: Graham
It's could be low fuel pressure, have you checked it's maintaining the pressure at high revs under load?
#28 mini-geek
mini-geek
  • 1,169 posts
Posted 26 February 2017 - 11:23 PM
It has fuel that's been checked, like I say he knows what he's doing
#29 nicklouse
  • 18,999 posts
Posted 26 February 2017 - 11:24 PM
The spring specs. As you asked for.
286 uses a set of VS2 springs. As to the number you have stated. You will have to ask KENT direct if it is actually one of their single springs.
#30 mini-geek
mini-geek
  • 1,169 posts
Posted 26 February 2017 - 11:28 PM
They where bought in a kit from Kent
I think the only way I can eliminate the valve springs being the cause is change them
