Fitting Show Plates.
17 replies to this topic
#1 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 02 March 2017 - 07:10 AM
Hi all bit of a random question, but does anyone out there have any good ideas for fixing show plates over your actual plates. i.e you pull up at a show and just want to put a plate over your own.
Does anyone have some good ideas, I mean there is Velcro, and I was thinking of some sort of bracket... pics, links and help invited :)
cheers
#2 greenmini1275
greenmini1275
  • 348 posts
Posted 02 March 2017 - 07:38 AM
If your show plates are metal use magnets.
#3 minimissions
minimissions
  • 3,427 posts
Posted 02 March 2017 - 08:44 AM
That's a good idea, cheers...
#4 Steve220
Steve220
  • 5,068 posts
  • Local Club: BMC
Posted 02 March 2017 - 09:31 AM
I always used to use bluetac
#5 nicklouse
  • 18,697 posts
Posted 02 March 2017 - 09:40 AM
use number plate holders.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 02 March 2017 - 10:29 AM
Low tack double sided tape.
#7 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 02 March 2017 - 10:56 AM
On my mx5 I've got the show plate bolted to the car, on some m6 studs, then slip my normal plate over the top, held by wing nuts. Get to a show, 2 wing nuts, take the normal plate off, instant show plate. Great for a bit of streeto too 😙🎶
#8 minimissions
minimissions
  • 3,427 posts
Posted 02 March 2017 - 10:58 AM
haha wicked thanks i just used straps in the past just wondered what everyone else does. Thanks guys.
#9 Ethel
  • 26,082 posts
Posted 02 March 2017 - 11:13 AM
There's a tiny risk someone official might take objection to you putting sticky out bits, like screw threads, on your car where there shouldn't be any.
Magnets sound good, especially if your proper plate is stuck on.
You could use some form of captive nut, if they're screwed on, to make swaps easier.
An under bumper front plate could just be hooked on with made up brackets, or elastic straps.
You could centre drill the screws for smaller screws, or pins - or replace with rivnuts.
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 02 March 2017 - 11:51 AM
I'd have thought very few show plates would be steel, not likely ali or plastic.....
#11 nicklouse
  • 18,697 posts
Posted 02 March 2017 - 11:55 AM
 for those that are not aware here are some from the VW scene. can be got blank or personalized.
 just fit your normal plates and swap out for the show ones.
simples.
#12 THE ANORAK
THE ANORAK
  • 3,946 posts
Posted 02 March 2017 - 12:45 PM
Wow, talk about over thinking a problem !!!
Get down to a local hardware store, find some suitable hooks and glue them on to your show plate level with the top edge... no brainer
#13 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 02 March 2017 - 12:50 PM
+ Number plate holders look ****.
#14 CityEPete
CityEPete
  • 3,920 posts
Posted 02 March 2017 - 01:11 PM
You'd need to be looking at 30s or 40s era plates to be magnetic!
#15 Colinmac1330
Colinmac1330
  • 261 posts
Posted 02 March 2017 - 03:06 PM
I use a bolt also, but with dome headed nut on the end. Then I can just swap over when need be.
