Steering Rack Loose?
19 replies to this topic
#16 Spider
  • 15,038 posts
Posted 29 March 2017 - 07:22 PM
Column spline failures due to lack of maintenance or the use of unsafe drop brackets have killed a number of people.
Is the steering column a maintainable item? I've never touched mine. Should I have done?
Depends on your definition of 'maintainable', I guess.
They certainly are rebuildable and that's all I ever do with them, top and bottom bushes as well as an overall clean & paint.
The one item though - for me - is a daily check when off road is the nut on the steering wheel. It does work loose, but is only a 10 second job to re-tighten.
#17 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 29 March 2017 - 07:46 PM
Is that the nut holding the wheel or the nut holding the wheel on?😁
#18 Spider
  • 15,038 posts
Posted 29 March 2017 - 10:46 PM
Well, yes both actually.
The Steering Wheel Nut and the Steering Nut :D
#19 Carlos W
Carlos W
  • 10,114 posts
Posted 30 March 2017 - 09:05 AM
You should check the pinch bolt remains tight as part of regular servicing
#20 tiger99
tiger99
  • 8,584 posts
Posted 30 March 2017 - 02:18 PM
Yes. Read your Haynes manual. The pinch bolt us required to be checked at every service. It is actually the most important check on the car.
