ignition starter
Posted 17 September 2006 - 06:54 PM
urgent
Posted 17 September 2006 - 07:20 PM
Or you could replace the key ignition with a push starter and then you wont need to worry about a key snapping in the ignition at all.
But yeh look around for a ignition barrel there are quite a few around and it will just be a simple swap.
Hope i have helped, Tomm
Posted 17 September 2006 - 07:26 PM
Posted 17 September 2006 - 08:06 PM
Or put a wanted add in the wanted section and youll have replies in seconds!
Hope ive helped you in some way mate, Tomm
Edited by tomm, 17 September 2006 - 08:07 PM.
Posted 17 September 2006 - 08:09 PM
Posted 18 September 2006 - 01:49 AM
Posted 18 September 2006 - 06:41 AM
Isn't there another issue here though? Yes a button starter gets over the starting issue, but doesn't your car have a steering lock also? Isn't that a requirement for MOT - just asking?OK, you broke the key off in the ignition. Have you tried to fish out the broken part of the key? Years ago in a non-Mini car I had a key break off in the door lock. I was at work and needed help right then. I called a locksmith who came to the scene, fished out the broken piece of key, used Mole-Grips to hold the broken key parts together and filed a new key for me (from a blank) using the broken one as a template. At the time it cost me $50 (25 GPB) which was big money at the time. However, I got home and I didn't have to buy a new lock.
Also of course there is the security issue - anyone can easily get into the car (the door locks are as useful as an ashtray on a motorbike), and then start the car easily.
I think if you try hard enough you should be able to get the broken part out as Doug says. Use fine gauge steel wire, or maybe a fine needle. You may even be able to disassemble the lock, and push the broken bit out (not sure about that though).
Posted 19 September 2006 - 10:36 AM
