for the past 3 times ive taken the mini out ive had a grinding noise then a sharp knock coming from the front somewhere. its not constantly happening, only for 2 seconds at a time then it goes away. on the three occasions its happened after i slow from 65-70 mph to 30 mph, what could it be? the sound is like the underside is catching the road. ive looked under the car and everything seems tight enough on the components. is it possible that a peice of metal is uplifting in the oil in the gearbox at high rpm and catching a gear?
mystery
blacktulip
, Sep 18 2006 09:06 PM
No replies to this topic
