Crank Bearings - Advice Please..
26 replies to this topic
#16 stoneface
stoneface
  • 399 posts
Posted 10 July 2023 - 07:16 AM
My post is only based on Mahle bearings as other manufacturers Racing bearings are likely to be made up differently.
They did say, in my situation with a tuned engine for road use, the standard bearing would be ok.
In the end I had no choice. My engine was line bored oversize and Racing bearings weren't available in the size I needed.
The king bearings website also has a lot of info for their different bearing materials https://www.kingbear...technical-info/
#17 DeadSquare
DeadSquare
  • 3,189 posts
Posted 10 July 2023 - 09:17 AM
How much larger had your webs been bored out to, and what bearings did you find ?
#18 stoneface
stoneface
  • 399 posts
Posted 10 July 2023 - 10:56 AM
This was not a mini block but my Ford block on mini gearbox. They were line bored +15 thou.
#19 DeadSquare
DeadSquare
  • 3,189 posts
Posted 10 July 2023 - 11:35 AM
"This was not a mini block but my Ford block on mini gearbox. They were line bored +15 thou."
Thank you for that information.
I thought that I might have found an answer to my difficulty.
I'd like to put a 1.75" Journal crank where a 45MM = 1,7715" crank used to be.
As Araldite might not stand the heat, it looks as though it is back to soldering .010" brass shim to the back of the shells.
#20 stoneface
stoneface
  • 399 posts
Posted 10 July 2023 - 11:53 AM
What size is the crank journal and what size is the block housing diameter?
I was after some standard sized thrust washers with tangs, and after a few hours searching the king bearing catalogue, which has thousands of sizes, I found one that would fit. Worth a try.
#21 GraemeC
GraemeC
  • 7,440 posts
Posted 10 July 2023 - 02:32 PM
https://www.fjpayne....-and-lineboring
(apologies this is more for DeadSquare and a bit off the OP's original question - although I think that's been answered)
Edited by GraemeC, 10 July 2023 - 03:36 PM.
#22 DeadSquare
DeadSquare
  • 3,189 posts
Posted 10 July 2023 - 04:15 PM
Thank you for drawing my attention to that.  One of the routes to our Daughter, passes Witney.
#23 DeadSquare
DeadSquare
  • 3,189 posts
Posted 10 July 2023 - 04:23 PM
Please may I apologise to the OP for jumping on a hijack, and now going off at another tangent.
Has anyone any experience of hard chroming main journals, as my other alternative is to increase the diameter by .0215" and bring it up to 45mm ?
#24 stoneface
stoneface
  • 399 posts
Posted 10 July 2023 - 05:41 PM
I had the bore of some helical gears reduced in size by hard chroming, which I then re-ground to size.
Not sure if it will add as much as 0.012" a side.
One difference is I was then installing bearing cups so not actually running against the chrome, but I know it is done.
The thickness might be the issue and they will have to selectively plate the areas which can be a pain and time consuming.
#25 stoneface
stoneface
  • 399 posts
Posted 10 July 2023 - 06:08 PM
Other option is thermal/metal spray transfer
I have and old eutectic kit in the garage but not used it in the last 30 years.
But, if you're going down the route of hard chrome or metal transfer it might well be cheaper to buy custom bearings the right size. Never done it so no idea of cost, or custom crank maybe.
#26 Icey
Icey
  • 1,553 posts
Posted 10 July 2023 - 07:42 PM
Just an aside, nice to see ABom79 posted here, great channel 👍
#27 DeadSquare
DeadSquare
  • 3,189 posts
Posted 10 July 2023 - 07:58 PM
I have had damaged crank tapers successfully metal sprayed.
