Twin Sus, Servo And Oil Breather
17 replies to this topic
#16 EasterBern
EasterBern
  • 52 posts
Posted 17 April 2017 - 07:11 PM
This is what looks like it'll fit on the Mini:
I also have this one:
But it must be from an Mg Midget I guess, as it's too deep - the carbs don't clear the bulkhead, though I haven't tried it with smaller spaces and studs.
#17 carbon
carbon
  • 2,590 posts
Posted 18 April 2017 - 06:31 PM
Angle between manifold face and the carb face should be 30 degrees for mini twin SU inlet manifold.
If it's 20 degrees then it's probably Midget or 1100/1300 manifold.
#18 EasterBern
EasterBern
  • 52 posts
Posted 19 April 2017 - 10:35 AM
I'd say it was less then 22.5 degrees, but I've just offered up the smaller manifold, with a carb and the air filter held in roughly the right place. The clearance behind and under the carb seems to be OK.
I've got pancake filters to go on the carbs, I was thinking about putting a 15mm tank fitting on both and then connecting the crankcase breather here. Being that side of the butterfly means that the pressure shouldn't be too much, and I guess that must be something a bit like standard (with the breather attaching to the air box).
I'll drill and tap the manifold and use that purely for the brake servo.
Thanks for all the help so far :-)
