Is there a kit I can buy with all the gaskets o rings etc that i will need to rebuild my metro 1275 lump with verto clutch?
Engine rebuilding kit?
Sammy D
, Sep 19 2006 01:37 PM
5 replies to this topic
Posted 19 September 2006 - 01:37 PM
Posted 19 September 2006 - 01:39 PM
i bought one from mini sport on 01282778731 last year.
good luck
good luck
Posted 19 September 2006 - 02:24 PM
i got mine from minispares.com
Posted 19 September 2006 - 04:23 PM
There are three gaskets kits available, Gearbox, engine ( or conversion set ) and head set, all of which have some cross overs in the gaskets they contain, but will fulfil you needs, additionally, you will need two diff output seals ( if you're rebuilding the box ) and an primary seal as neither are contaned in any of the gasket sets. Also the head set will have a some carp head gasket, would recommend you use a BK450
Any mini specialist will be able to provide them..
Posted 19 September 2006 - 10:43 PM
Thanks people!
The engine has only done 50k. Do you all think it really does need a re-build?
Posted 20 September 2006 - 07:06 AM
Here are links to all that you would need-
Head Gaket Set With BK450
Block Gasket Set, For A and A+
Gear Box Gasket Set
Clutch Oil Seal
Out Put Shaft Seals - 2 Required
Hope that helps a little.
50000 isn't really that much, but it depends on how it has been driven and maintained. Is it making any unusual noises or leaking much oil?
Gear Box Gasket Set
Clutch Oil Seal
