http://minispares.co...31.aspx|Back to
Edited by Dandung86, 16 April 2017 - 11:40 AM.
Posted 16 April 2017 - 11:38 AM
Posted 16 April 2017 - 09:55 PM
yes correct type
Posted 17 April 2017 - 06:20 AM
Posted 17 April 2017 - 08:08 AM
Posted 19 May 2017 - 06:53 PM
Edited by Dandung86, 19 May 2017 - 07:13 PM.
Posted 23 May 2017 - 08:56 PM
Posted 25 May 2017 - 09:31 PM
its a stubborn job getting the old ones out and if you are contemplating this then I advise you to remove the outer frame first then find the rusty old screws that hold the bottom channel in once these have been removed then there is a black plastic glass stop holding the rear glass from sliding forward remove this as well then slide the 2 windows into the middle and hold onto them as you pull the bottom channel outwards once this is done uou can remove the2 side channels and top channel screws should be ok, now you can see how good or bad the metal is and repair if necessary also the outter frame can be treated for rust and primed and painted refit the frame to body then use sicaflex to fix new bottom channel to body now things can get tricky you will need another pair of hands a friend on the outside of car and you inside place the front glass in outter channel and the rear glass in inner channel now get your frienf to hold these whilst you insert the upper channel on to the top of glass and then push the windows into frame then screw upper channel into place then use sicaflax to stick side channels into place job done now repete on the other window
Posted 02 February 2024 - 01:55 PM
Old thread i know, but i have a query. How does the top of the frame fit to the car body, I have holes in the body as if there should be fitting studs like the lower frame, however i see in all pics the top of the frame surround has no studs, and also theres no cut out slot in the top frame to slide them in and out. Surely the top needs securing ??
